Major tire vibration
rcjmaxx
Major tire vibration - 04.30.2006, 07:45 PM
I bought a used OFNA Titan monster truck roller,after converting it to brushless I found that at about 30 mph it swirves sharply out of controll.Some suspension adjusting made a small difference.With the truck suspended and all 4 tire off the ground,I ran the rpm's up a little and you could see all 4 tires VIOLENTLY shaking and vibrating.I'm assuming the wheels/tires are out of balance...but at 30 mph? Am I assuming correctly? Is there a solution to this problem? Thanks in advance.
coolhandcountry
coolhandcountry's Avatar
04.30.2006, 08:27 PM
At 30 mph the tires are spinning pretty quick. Make sure they are glued good. What tires are you running with what rims to?
Peace!
Country
Help support the
Rc-Monster
Buy here
rcjmaxx
05.01.2006, 05:47 AM
I'm running stock Titan wheels and tires.
stampy
stampy's Avatar
04.30.2006, 09:27 PM
check the bearings in the hub and the hub it self make shur there isent any slop in ther
cabking
05.01.2006, 09:02 AM
Check to see that the foams are not full of mud, this can really unbalance a wheel
Sneeck
RC-Monster Custom
Sneeck's Avatar
05.01.2006, 11:02 AM
If the above tip's don't help, you can glue spot's of hotglue on the tire to balance it, like they do on real 1:1 size rim's with strip's of lead. They do this allot on truggy's now, Ballistic even make's a tire balancer stand thing.
  Send a message via MSN to Sneeck
Serum
Serum's Avatar
05.01.2006, 11:21 AM
If you can't tell what wheel/tire is wobbling/vibrating, you can use a bolt and a nut to put it in your drill.. and look at it shaking..
it might be water.
05.01.2006, 12:43 PM
Originally Posted by Serum
...it might be water.
This is why I glue the tires really well, and do not drill holes in the rims for air release even though it is recommended to do so...
cabking
05.01.2006, 06:15 PM
I punch 4 small holes equidistant along the centre line of the tyre, not the rim
If any water does get in, the centrifugal force ensures it doesn't stay. :003:
coolhandcountry
05.01.2006, 06:38 PM
Does that make the tire weak in any way?
It is a good way to keep the water out or get it out.
I would be afraid of making the tire maore likely to blow apart.
Peace!
Country
Help support the
Rc-Monster
Buy here
Sylvester
Sylvester's Avatar
05.01.2006, 06:51 PM
The holes arent big, leroy. It wont rip, since your not ripping apart half the rim.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
stampy
stampy's Avatar
05.01.2006, 06:53 PM
ya i dont like the idea of putting a hole in my tires cause it probly would cause it to rip if youve got some power under the hood
cabking
05.01.2006, 06:59 PM
sylvesters right, no more than a 2/3mm hole, I use a leather punch.
I got this tip from the 1:8th rallycoss guys many moons ago, Ive never seen one rip yet and I do have some serious power under the hood. :027:
coolhandcountry
05.01.2006, 07:04 PM
What kind of power is under the hood?
Serious power I am thinking 2250 or so.
Peace!
Country
Help support the
Rc-Monster
Buy here
cabking
05.01.2006, 07:23 PM
Well that is serious power chc, and not one Ive had any experience with.
The 7XL on 18 cells is more than a match for my driving skills.:032:
Its still yet to blow a tyre..................we live in hope :027:
