Motor rebuild kits: 1410 and 1415 -
07.11.2011, 11:54 AM
We are finally ready to start shipping the motor rebuild kits for the 1410 and 1415 motors. Like our other rebuild kits, it includes the rotor, front endbell with bearing, extra bearing, rotor shims and endbell screws.
We have 4 different rebuild kits available:
1410 w/3.2mm shaft (P/N 011-0022-00)
1410 w/5mm shaft (PN 011-0023-00)
1415 w/3.2mm shaft (P/N 011-0024-00)
1415 w/5mm shaft (PnN 011-0025-00)
So yea, if you're looking for a 5mm shaft for your 1410 or 1415 we finally have an upgrade option. Enjoy!
Thomas Porfert
Tech Support
Castle addicted
07.11.2011, 01:52 PM
Thomas
Best news of the day !!!!
Thank you Castle !!!!
kind regards
Mirko
Brushless motors have to be green ....
07.11.2011, 01:59 PM
No 1406 kits? Oh well the endbells on the front are all the same right? Guess I will just have a rotor for sale unless someone has a front endbell and bearing(3.2 mm) they would be willing to let go. My buddy has a rig dyin for this 4600 1406 four pole.
Castle addicted
07.11.2011, 02:12 PM
Thomas
Can i also order a 1415 with 5mm Shaft on the Castle Website ?
Would save me buying the extra rotor
kind regards
Mirko
07.12.2011, 03:31 PM
Originally Posted by outlaw
Thomas
At this time we are not producing the 1415 with a 5mm shaft. There may be plans in the future to make one, but there is nothing in the works right now.
They are in the works, no kind of ETA yet though. We just got a new internal pricing list and there is a part number for it now; but no pricing and the notes just say coming soon. It will have the 3.2mm shaft, no plans on making a repair kit for the 1406's with a 5mm shaft.
Unfortunately the front endbells are not the same between the 1410/1415 and the 1406 motors. The 1406 has a shallower bearing recess on the inside of the endbell, so if you try to use the one from the 1410/1415 the deeper bearing recess causes it to press against the rotor and bind ups the rotor.
Thomas Porfert
Tech Support
07.12.2011, 03:05 PM
AFAIK, the bearings are the same on the 5MM and 3.2MM shaft models. The shaft is 5MM where it goes through the bearings.
07.12.2011, 03:03 PM
Thomas Porfert
Tech Support
Got a question on these (sort of). Since they have been out, I have had 6 different 1410 motors in my possesion. The first three (manufacturing time wise) had wires about 4-5 inches long. The last three have wires about 8-9 inches long.
Interesing observation: There is a significant difference in the magnetic detent strength between the early motors with the short wires and the later motors with the longer wires. About as much and maybe even more difference than between a Castle 1512 and a Castle 1518 (both of which I own). Another way to characterize this: The difference in magnetic detent strength between the short wire 1410s and the long wire 1410s is greater than the difference between the 1406 and the short wire 1410. At least to my fingers.
Is this difference because of a change in the magnets? And so the real question: Do the rebuild kits have the same magnets on the rotors as the later 1410s with the long wires?
I'm sure the length of the wire is incidental, and just indicates a running change in the spec for wire length but it curious that all the long wire motors I've had have apparently stronger magnets.
I realize this effect could, alternatively, be a design change in the stator, so I'm asking the question.
08.18.2011, 02:52 PM
My Guess is that the amount of Neo mag material may have decreased, due to the increase in price.
I noticed in the latest RC Car Action that you are now going to offer the 1410 with the MM Pro in a racer SC package w/5mm rotor, Can that package be got with a 1/8 rotor? I have an ST (T4) that i would love to use that in, But finding 5mm 48 pitch pinions will be a Bugger and a rebuild kit just to convert would be a watse
08.18.2011, 03:09 PM
I'd swap you a new unused 1410 I have with a 1/8" shaft for that new unused 1410 with a 5MM shaft - it would save both of us buying rebuild kits (sorry, Patrick) or having to take the motors apart.
08.18.2011, 04:36 PM
The motors I am talking about were all manufactured and purchased before the price change.
08.19.2011, 01:31 PM
ok, figured it was a possibility. Could be the mass of the longer wires is holding the magnetism better, I know the wires are not touching, But can the wire length effect the feel of the magnets?
08.19.2011, 06:54 PM
No.
08.19.2011, 07:06 PM
There has been two small changes in the magnet design on the 14xx series since we started building them.
Neither of them has anything to do with the cost of magnets (unfortunately.)
One was to make the rotors more consistent from production run to production run (magnet alignment)
The other was to improve back-emf matching.
So yes, you might feel some difference between earlier and later build-date motors.
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
08.19.2011, 11:51 PM
Thanx!
Patrick
Thank you. But now:
1) What does "improved back-emf matching" do for us in terms of motor control, driveability, or performance?
2) Would it be correct to assume that since the rebuild kits came out after the first of the newer dresign motors with the stronger detent feel, that the rebuild kit rotors would be the same as the newer design rotors in the motors?
RC carbon junkie
07.12.2011, 06:22 PM
Awesome
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
