Tekno Emaxx Wing Mount
USARUSH
Tekno Emaxx Wing Mount - 09.29.2011, 04:21 PM
Has anybody broken one... I have, its just the little metal crossbrace that attaches to the shock mounts... Any advice as to fixes or parts numbers... Im using zip ties at the moment
09.29.2011, 07:04 PM
Trace it only some thicker aluminium sheet/plate ( 1/8" or 3mm should do nicely ) and cut out a new one- you only need a hacksaw, cordless drill and some small hand-files.
USARUSH
09.29.2011, 09:55 PM
That is sooo much easyier said than done.... I think I may stick with my zip ties till I get some FLM shock towers..... Mostly cause I'm lazy, partially cause Im not sure if I could ACTUALLY work the metal without drawing my own blood
The things we do to keep our wings?????
Thanks Neil
crazyjr
crazyjr's Avatar
10.06.2011, 10:56 PM
Dude, I am the laziest guy i know and a fair bit clumsy. I made an adapter for using a RC-monster Revo motor mount in a RC10GT, It only took 20 minutes and no blood. Most any lowes or home depot type store has the material and it shouldn't take more than 5 minutes to make. But i guess Zip-ties can work
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
10.07.2011, 09:24 PM
http://i264.photobucket.com/albums/i...v/100_5560.jpg
Or just make it a square and drill the holes in the right spots. who said it needed to be an X shape. I sandwiched a shock tower and then used ball links for spacers inside... The wing mount bolts right on there very simple
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
USARUSH
10.07.2011, 09:34 PM
So what did you use to cut that metal???
Looks rough, but tough as nails
George16
Supermaxx
George16's Avatar
You can do it. It's easy. "If there's a will, there's a way".
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
USARUSH
10.07.2011, 10:04 PM
Oh, I'll get er done all right
to tell you the truth the wing is wayy down on the to do list with ma MAXX
I got 1/8 diff problems
Always something with MAXX
George16
Supermaxx
George16's Avatar
10.07.2011, 11:49 PM
What's your problem with the diffs?
Revo with OS .18TZ
USARUSH
10.08.2011, 08:37 AM
Im going to move this over to the UE thread
