Originally Posted by Rcbros
Can you probably gear a truggy with only a 44 or 46 tooth spur?
I always thought truggys use a larger spur then the buggys.
would it be bad to run a steel spur?
Yes, you can gear one properly, but it would be alot easier with something like the LSP diffs. The Lightning Stadium comes with 4.3 to 1 ratio diffs instead of 3.31 like buggys and alot of truggies. Alot of the earlier truggies did indeed use a 60+ tooth spur. I wouldn't recommend a steel spur. The steel spur would require hardened pinions and there quite expensive and aren't the best way to go. Plastic spur is definately the way to go...
