I have an MGM 8012 and a Feigao 8s running on (6) GP3300 cells. My stampede runs great up until FT where it cuts out completely. Anything over 75% throttle and there is total silence. However it will not do this if I hold the truck in my hand. (Only under a load)
So far I have:
1. Adjusted the timing and eventually went back to the auto setting.
2. Changed battery packs
3. Changed low battery cut-off point.
Ok I'll try the default setting tomorrow and see what happens.
I bought the motor and controller used and this is my first attempt at using it. (I did see it work before I bought it though.)
My guess is the batteries may be old and don't have enough power anymore. I really haven't used them in about a year. The previous owner was running 10 GP3300 cells when I saw it and it ran great.
Well no luck yet. I set the controller to default settings and though it's smoother it still cuts out at WOT. I messed around with the settings a little more. I noticed the more I advance the timing the worse it is. At 10 deg timing it coggs bad then jumps then cuts out.
The weird thing is it starts to work then cuts out again. If I let it sit for 30 seconds it screws then eventually cuts out again. The motor, controller, and battery never even get warm.
I'm starting to think I have a bum controller. I'm going to try more cells and maybe a different gear ratio.
As I suspected my cells are tired. I added 2 cells tonight (8 total) and the truck was crazy. The front end was coming up at any speed and the controller was not shutting off at full throttle.
Once the pack wore down (4 minutes) the problem came back due to low voltage.
