I'm New So I Have A Couple Questions. I Bought The Revo Electric Motor Mount,i Wanted Know What Pinion And Spur To Run And How To Set The Driveline. Open To Any Input:027: Thanx From Hawaii:043:
You can use the stock pinion and one of the mod1 pinions on this page since the Revo uses a Mod1 pitch for the spur. The bore depends on the shaft diameter of the motor you get, typically 5mm bore. Toth count depends on how you configure the tranny.
BrianG, do you mean stock spur?
