nitros.
J/K, Its a UBEC. I have a 2s 1000mah lipo below it. Some of the extra cabling is from the series lipo connector that I made so it looks worse than it really is.
If I can wrap up the last vid Ill post some of the other pics on my main forum. But, you cannt have a work in progress vid after finished (or near at least) pics! Its just not right!
But, since this place has helped me out with getting the quark, pinions, the crt.5 motor mount, and the e-mugg's heatsink...well, its only right to post some pics as well! The carbon fiber sheets from FullforceRC really came in handy as well. Where I would have normally cut alum to munt stuff to I was able to use 3mm CF. Which saves weight and I think that its easier to cut (though riskier).
I did run it last night in the house (CRT). It cogged like no tomorrow with the 7700 in it! A couple of setting changes on the pc and its as smooth as butter. Of course, it also hurts when it hits the ankles!!! I just dont want to run the chance of hurting the coax on the 2.4ghz fasst receiver so Im going to save speed and outdoor trials for when i get that mount. I think that I might regret not getting the 4600 (or a second one at least) but... Ill make this work
Also, better pics of the emuggy's water drop body-
