Brushless Wiring Question
Thunderbruiser
Thunderbruiser's Avatar
Brushless Wiring Question - 06.11.2007, 12:04 PM
Hey i thought you couldn't directly soldier wires to motor tabs but in rccar mag pros have theirs directly wired from esc to motor with no connnectors...will this destroy the sensorless mamba? i have 3.5 mm connects so i'll be using those but i was just wondering
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
06.11.2007, 12:08 PM
Who says you can't solder direct? That is always the recommended method, but makes disassembling stuff a bit more difficult.
Thunderbruiser
06.11.2007, 09:11 PM
i read that on one of my older brushless esc's it said something about never direct link...unless i miss understood it lol
garage:
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.11.2007, 11:10 PM
Hmm. Sounds like a bit of misinformation, or like you said, misunderstanding. Direct soldering IS the path of least resistance, and therefore highest efficiency and power. Although some type of silver solder works best IMO.
AAngel
06.11.2007, 11:55 PM
Even if you don't direct solder, I'd get rid of those 3.5mm connectors. They have to lowest amp rating and loosen up pretty quickly.
