BLMGT & KB45, 8S, 3700mah 20C, Video -
09.09.2007, 08:51 AM
Video of my first run last week... it moved pretty good. I couldn't go more than a little over half throttle. It seems just to wheelie and flip over whenever I give it full throttle on the high grass. The car was acting funny after half way because the spur was melted in the center. I forgot to put some slipper pegs on the spur.. :) I will try to get a faster video of it... I changed to the KB45 1700kv motor.. so it's a little hot, but who cares... I trimmed down the throttle EPA to 90% so the motor doesn't get too close to 50K rpms... I was using stock tires.. anyways... here's the video.
it actually wasn't that hot at all.... I don't know know about reliability yet, but it seems to be fine.. for $50.. :) can't go wrong... I would rather buy 8 of these instead of my one 2280... that's for sure.. I wanted to make another video today but it's pouring.. we were suppose to be racing today. :D
It can be faster.. it's never fast enough Capt.. :)
What did you do for 6mm pinions?
Does it have the same mounting pattern as a standard 540? Or that off a 22xx?
Also, how do you think it would perform on 6S in a lightweight truggy?
posted comment on youtube. make sure you got your 23mm hex conversion on order. those stock 14mm lasted me less than a week. i just went to the max size 23mm wheels from proline and used stock tires. (boiled them off)
if you dont know already the slipper is a joke. make sure its locked all the way down or you will continue to melt gears
