Batt Strap behind strg servo ??
Duster_360
Batt Strap behind strg servo ?? - 11.17.2007, 07:29 PM
I just got my strg sorted out and servo mounted on the flm chassis, but now there's no room for the front attachment point for the gorilla batt strap I was planning on using. I can get screw for the strap in by itself, but need to use the rubber sided washer. Do you mount the front of the strap on the underside here??
Suspect I'm not first to have the prob - is there a good solution out there? Anyone have a nice, neat solution??
squeeforever
squeeforever's Avatar
11.17.2007, 09:26 PM
If you could post a picture of exactly what you have to work with, we might be able to help a little more.
Duster_360
11.18.2007, 12:28 AM
I'm charging the canon's batt now. I'll have a pic up in the am.
Duster_360
11.18.2007, 02:45 PM
Sorry for the delay - here is pic
The hole to the right behind the strg servo is where batt strap is supposed to go. Obviously can't get there with the rubber sided washer used with the gorilla strap. I you use it without that washer, strap will tear. Suggestions?
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
11.18.2007, 04:51 PM
even WITH the washer, the strap will tear. i had the same setup and tried gorilla crap straps, and ripped through 3 pairs before i just gave up. they'll tear where the washer presses into the strap.
back when i had the FLM chassis, i made my own straps - found some military-strength 2" velcro on ebay and wound it all the way around the frame and batts. you can go through the spaces in the frame where the batts fit.
Eflite Blade 400 heli on 3s
squeeforever
11.18.2007, 04:38 PM
Could you go from the underside?
Duster_360
11.18.2007, 05:07 PM
That was the same thing I tought off, but its pretty much the same from the other side too, again due to the strg servo and mounting screws. This is a design joke - there is no way straps/washer can work and if you use the 2 speed, its the same problem on the other side too.
While I've been reading here today, I see now the gorilla straps are not that highly regarded (crap straps indeed, lol!), so I guess I'll be looking for some wide velcro like you used Clodmaxx.
I guess this means I can't rely on these for my G2R either. Another parts quest begins....
Thanks guys!
ClodMaxx
ClodMaxx's Avatar
11.18.2007, 05:13 PM
sent you a PM, duster.
Duster_360
11.18.2007, 05:35 PM
Thanks Scott, sent you a paypal. Appreciate your doing that!
ClodMaxx
ClodMaxx's Avatar
11.18.2007, 05:55 PM
no problem - glad i can help out.
