ok. i want some SERIOUS advice -
11.18.2007, 03:11 PM
im building a e-revo, with a motor mount and CD custom made by MetalMan (just like his) and stock diffs. i really want to use the MM esc because my LHS still has the old one (itll run 5s!!) this rig will be about 8-8.5 lbs with batts (trueRC 4s 4000mAh packs, or 5s 4000mAh packs) id like lots of power, good availability, lightweight, and a price of under $350 or so. i am in the US, so its hard to get a plettenberg, but i like the lehner 1930/40 series alot, because of price and weight..... brians speed calc says i need a kv of around 1100-1700 with the CD instead of tranny unless i run super low gearing (it recommends the 1930/9 with 10/46 gearing!   if you know of a great motor, that i can get fairly easily, please LMK!
11.18.2007, 03:40 PM
can you post the specifications? that's a slow turning motor with a high gearing ratio! Something must be wrong here.
11.18.2007, 03:50 PM
specs of what?
11.18.2007, 03:58 PM
the speedcalculator results.
Please post them..
11.18.2007, 04:45 PM
Here's what I came up with:
Vehicle Weight (approx): 10
Desired top speed in MPH: 40
Differential Ratio: 2.8461538461538462
Transmission Ratio: 2.2
Additional Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 20
Battery Voltage: 14
Tire Diameter (inches): 6
Total Ratio: 12.52308 : 1
Tire Circumference: 18.85 inches (478.779 mm)
Required Motor RPM: 28062.983 RPM
Required Motor KV: 2004.499 RPM/V
Good Motor Choices: BK Wanderer 9 XL (kv=1853)
BK Wanderer 8 XL (kv=2084)
Better Motor Choices: No motors of this class fit the parameters you entered.
Best Motor Choices: Neu 1515 1y (kv=2200)
Neu 1512 2.5d (kv=2000)
Neu 1512 1.5y (kv=1900)
LMT 1940/9 (kv=1742)
LMT 1940/8 (kv=1959)
LMT 1940/7 (kv=2239)
Neu 1521 1.5d (kv=1860)
LMT 1950/7 (kv=1867)
LMT 1950/6 (kv=2178)
11.18.2007, 04:58 PM
12:1 FDR? that does sound rather high for a large MT type vehicle- and only 28,000rpms on 12cells. Im no expert, but that sound like an under powered & overgeared setup... I could be wrong though.
11.18.2007, 05:33 PM
Well, since I own Metalman's old revo with the sliper/diff setup I may be of some help.
Now I have one issue, the motor that Mailman sent me is supposed to be a 7xl, but according to BrianG's calc and my radar tests it must be an 8xl. In any case here is the speed calc with an 8xl and 46/20 gearing:
Other Ratio: 1
Spur Tooth Count: 46
Total Voltage: 14.8
Motor KV: 2084
Tire Diameter (inches): 5.75
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 2.3 : 1
Total Ratio: 14.40154 : 1
Tire Circumference (inches): 18.06 inches (458.83mm)
Total Motor Speed: 30843.2 RPM
Vehicle Speed: 36.64 MPH (58.85km/h)
Effective Speed Rate: 2.48mph/V (3.98kmh/V)
Effective KV Value: 2084
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
I am currently running 40/20 gearing and while the motor stays cool, the mm is very hot, as are the 5k batts I am using. The 46/20 kept everything much cooler. The lehner 1950 may be able to handle the higher gearing better than the feigao. I have had Griffinrn mod a mm for me and I need to install it and see how it does with this combo. I also have a pair of 4000 14.8 lipos to replace my pair of 2s 5k lipos. So 8k mah compared to 5k should help with batt temps. It is a good setup and the slipper/diff make the steering very good. Also has a low CG, so it is more stable.
11.18.2007, 05:32 PM
Yeah, I think that FDR is abit high too. Also, look at the total motor speed in MM's post; 28k rpm. You'd need to gear up pretty high to get the speed you want with that motor speed. I would suggest going with higher voltage or slightly higher kv motor to get rpms in the 35k range. Then you'll see you won't need such high gearing.
11.18.2007, 11:25 PM
With the Revo that Lincpimp has now, I ran a 7XL on 5s2p A123 with 20/46 pinion/spur. It had plenty of power, and 40mph top speed was enough for me. The 7XL ran at a good temp, but as Lincpimp noted, the MM runs hot.
Z-Pinch racer
11.19.2007, 01:55 AM
Yeah, I found that the 7XL has loads (s**t loads) of power on 5s2p, but it also takes s**t loads (huge s**t loads) of power from the battery. Drawing 135amps consistently.
Reason: Language. :)
11.19.2007, 11:26 AM
ooooh! you cussssssssssseeeeeeeeeeddddddd iiiiimmm teeeeellllllling!
KillaHurtz
11.19.2007, 12:21 PM
I too have the TrueRC 4K cells, but in an 8K pack. I think 4K is too small. I think the motor you are looking at is a bit small too. A 1940 at a min. A 1940/7 on 4S would be great. The MM may or may not like 5S, I wouldn't bank the setup on it.
You should be getting ~120A peaks, which is alot for a 40A continuous cell. Driving is very peaky, and I think you will overdraw and heat up the cells. If you really want low weight you got to pony up a bit. I'd at least get the 5K cells if you are determined to stay cheap and 1P
Z-Pinch racer
11.19.2007, 08:49 PM
You little tattle tailer!!
11.18.2007, 05:43 PM
Hi lincpimp
I ordered the 7XL - starluckrc may have sent me the wrong one. I think the KV rating is marked on the enbell. 2084kv for the 8XL and 2382kv for the 7XL. I never paid attention to it when I got it - I just assumed they sent me the right one.
11.18.2007, 05:47 PM
IIRC it is labeled as a 7xl, but I could only get 36-37mph out of it so the calc seems to think it is an 8xl. I have a 7xl in my terror, so I may swap out and try it. Not sure why the mm gets so hot and the motor stays cooler?
