Originally Posted by nl12
I think an outrunner will be too big to fit between the chassis rails
How much room do you have between the chassis rails?
Give me the length/diameter of the output shaft to the transmission and I'll try to make a 12 pole outrunner recommendation for you.
There are all different lengths, diameters and kv outrunners out there.
IMO, anything less than a 12 pole outrunner Direct Drive probably won't work.
How heavy is this vehicle? Tire size? Diff ratio?
