Serum
Serum's Avatar
05.23.2007, 01:12 PM
If it makes you feel better, go for the 125B!
Here is the deal;
125X14V=1750W
80X14X2=2240W
05.23.2007, 01:21 PM
I'm a nitro guy trying to convert to electric, so i don't have a FEEL for anything yet. But I do work in electronics and understand a few things about heat effects and running electronics backed off from their maxx ratings....
Serum
Serum's Avatar
05.23.2007, 01:32 PM
In less words; yes, i think two 80B's would survive... :)
05.23.2007, 01:41 PM
This fits? Pics installed?
Procharged5.0
Procharged5.0's Avatar
05.23.2007, 01:51 PM
The Dual mamba maxx 5700's sounds like the best bet to me.
05.23.2007, 03:00 PM
well 1.7" long is going in correct direction! I'm starting to think these are the smallest motors that will fit the Emaxx???
Serum
Serum's Avatar
05.23.2007, 03:44 PM
I would not use these small motors personally; if you want a real deal 2 motor setup, do it the right way, or stay away from it. that's my opinion. like i said; use 4S on the setup; the 5700 can't take 4S, and running it 2s makes it even less efficient.
You might like symmetry, but using two 1/10th scale systems is quite a missfit IMO..
05.23.2007, 03:45 PM
Unless someone has a better suggestion, I'm going to have to agree with procharged5.0.
05.23.2007, 03:50 PM
Serum, wouldn't a pair of these or 6900s on #S get the job done with two smaller motors...I guess one big motor on 4S would be more efficient, thanks for your patience....
Serum
Serum's Avatar
05.23.2007, 03:57 PM
You could use two small motors on 4S as well, which makes it more efficient. np on the patience, i am just no fan of the tiny-micro rotors that are in the mm motors. even two are not enough. a wanderer/feigao S motor delivers more torque.
But if money is an issue and you can agree with a huge compromise you could set for the dual mm setup..
It's not my advice though.
Serum
Serum's Avatar
05.23.2007, 03:59 PM
Or two MM controllers and two basic XL motors.. One basic XL motor (2400) on 3S lipo delivers impressive power in a 7lbs heavy maxx.
05.23.2007, 04:18 PM
So the Lehner 10th scale motors are just better than the Mamba 10th scale?
05.23.2007, 04:21 PM
BTW what do you think of that outrunner setup on ebay?
Serum
Serum's Avatar
05.23.2007, 04:32 PM
Yes, they use segmented magnets, but Neu is my favorite over Lehner.
that outrunner; i wonder what it does in real life, (how hot it gets etc) because an outrunner is meant for a fixed RPM, and not for a constant variation in rpm's. the moving mass is located rather far from the center, which makes them less ideal to respond fast to the vehicles behavior.
0700
05.23.2007, 04:46 PM
That's good info :028:
got a link to neu 10th scale cans?
