06.23.2007, 11:20 PM
Originally Posted by ***RC***
Patrick - The dimensions of the battery are 44mm x 50mm x 145mm so I do have to kind of squish into place (I use the 50mm side down), but it isn't so tight that it will damage the battery.
Ok, thanks. So it's a Kyosho Twin Force battery tray from Mike.
06.23.2007, 11:41 PM
Correct.
That's All Folks!
06.24.2007, 01:50 AM
Thanks guys.
It looks like 15 min is exactly what I get with the 3700 flightpower. I will have to do a little more running to see, it was the first run on the pack. That is cutting it too close for a race, I may have to stick with the maxamps 5000. Still not bad on weight at just over 7.5 lbs with the 5000. Or maybe try the 4000 maxamps packs, but I hear they are not as good as the 5000's (anybody know?). I think all of the higher capacity flightpowers are heavier than the maxamps 5000, maybe not the 4350, but I can't find size/weight on that one. Also, I start to pucker up when I gotta pay $200 for batts, so the maxamps are more my price range.
06.25.2007, 02:48 PM
Bruce, stick with the 5000s. I don't think that the 4Ah packs would be able to keep up.
As for the Feigao, you can toast one of those within 10 minutes. It depends on your setup. I went to great lengths to be able to run mine for a 30 minute race, but it still temped at over 200 when I was done. The Feigaos run hot. No way around it. If you want to get away from the heat, get a better motor. Neu or Lehner.
That's All Folks!
06.25.2007, 03:35 PM
qbayle, love the pic with the nitro trying to get started,LOL. Good job on the races too. That temp sounds about normal for the XL motors.
I never ran a 9XL in mine, I ran a 7XL and an 8XL. I have seen temps up to 200 on the 7XL and about 185 - 190 with the 8XL. I did however have the 8XL go T.U. after a few runs, brakes dissapeared and all the wires got real hot. The 7XL still runs strong, but pretty hot. I like the lehner 1930/8 I have in there now; it still gets up to 180 at times, but cools right back down with a little more "sane" driving.
AAngel, I think you are right about the 5000's. I talked to Austin at Maxamps and he said the same thing. I guess it's not too heavy, at a little over 7.5 lbs. I just didn't want to carry anymore weight than I have too, it handles so nice with the light batteries.
Well, I guess I could put the 3700 Flightpower up for sale, only a couple runs on it and it already has the Deans plug. PM me if you want to make an offer.
06.26.2007, 09:34 AM
I added a lot of mass to the motor can on mine. I turned a heatsink that completely encapsulates the motor and I made it rather tight, so that I had to press the motor into the heatsink. It still gets hot, it just takes longer.
06.27.2007, 06:27 AM
Very nice car.
06.27.2007, 12:25 PM
Bde Bde, that buggy looks totally awesome with the green body that has no nitro holes, do you know how much your temps went up?
Qbayle, I gotta love that startup picture.
That's All Folks!
06.27.2007, 01:01 PM
Temps seem to running about the same, maybe a few degrees warmer, but not much. I have the "hood scoops" cut out to give some good air flow over the motor.
09.27.2007, 12:00 AM
what are you guys using for the motor mount??
09.27.2007, 12:13 AM
When it comes to the motor mount, there is more than one way to do it, but all of them include making a custom part. I made mine out of 1/4" think aluminum plate and attached it right to the rear center diff bulk.
09.27.2007, 08:03 AM
how does the xl motor run on the flightpower 3700's? that is 4s correct?
That's All Folks!
09.27.2007, 09:34 AM
Mine was the same, only 3/16" aluminum.
09.27.2007, 02:41 PM
Actually, 3/16" 7075 is the way to go. It is plenty strong and easier to work.
01.01.2008, 05:56 PM
nice mayhem really clean
Linear Mode
