charger/balancer question
t-maxxracer32
t-maxxracer32's Avatar
charger/balancer question - 08.24.2007, 03:36 PM
so im using the hyperion 1210i and the lba10 balancer. when i plug up everything it all seems fine but when i go to charge it it sais "output battery connect error"
what can cause this? im charging a 2s 8ah pack and using a custom PC PS.
thanks!
o and WAHOO!! old rcm is back!
08.24.2007, 03:46 PM
You gotta press the mode button on the LBA10 so the LED is flashing...
Serum
Serum's Avatar
08.24.2007, 03:50 PM
You only need to update the avatar t-maxx.
t-maxxracer32
08.24.2007, 06:02 PM
hmm i will try that. but the 2s light is flashing
shady3031
Brushless Rookie--Please Advise
08.25.2007, 01:46 AM
when you first plug in the balance harness press the modr button once and the led that says lipo 3.7v should begin to flash intemittently--then proceed with your charge.
FG101C
09.10.2007, 10:37 PM
I just got one of these balancers and the only "Mode" led I can get to come on is the A123 led. The LiPo led will not come on. Any ideas?
zegato
09.18.2007, 10:10 AM
probably you pressed the "mode" button during your trials and switched the lba10 to a123 mode. I got the same issue and, by re doing carefully the steps and pressing (one or twice) the mode button when connecting the pack to the LBA10, I came back to lipos.
And then you may charge with the 1210 without problems.
