MM + 9L on 12cells in med. weight maxx
I Trust Tyler
I Trust Tyler's Avatar
MM + 9L on 12cells in med. weight maxx - 11.23.2007, 04:06 PM
I originally had a 9920/7xl with 16-18cells in my maxx, but for some unknown reason the esc stopped working..whatev's im done being pissed about it. I have a couple of MM esc's not doing anything currently and i have been fiending to run my maxx. I just ordered a 9L and wanna run it on 12 cells just to use my maxx, this should suffice as long as i have the proper gearing and convert back to stock size wheels/tires right? thanks ppls.
bluonyx
11.23.2007, 04:34 PM
A 9L is gonna run hot on a Maxx. You'll wanna switch to a XL motor or maybe run a fan on that 9L to keep it cool.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
11.23.2007, 07:10 PM
a 12 XL would run nice with 18 Cells bro... get that instead..
7XL and MM works great too on 12 Cells.. I also have this on one of my maxxes... it's all good with just a fan...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
I Trust Tyler
11.23.2007, 10:55 PM
yeah im probably gonna try the 7XL and MM combo, i've never use a fan before...what fan did you use and whats the best way to wire it up. thanks
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
11.24.2007, 12:33 AM
a 9L won't run too much hotter than an XL, all the feigaos run hot no matter what.
jnev
jnev's Avatar
11.24.2007, 01:18 AM
I can't recommend a specific fan, but the way I wire mine up is to use a "Y" connector to split the external BEC and fan, to go into the "battery" slot in the receiver. It has to be a 5V fan though I think.
aqwut
aqwut's Avatar
11.24.2007, 02:09 AM
I use a 30mmx30mmx10mm 12Volt fan... and connect the fan directly to the battery leads... so the fan is good for up to 4S...
