Mamba Max with a 4s
azjc
Mamba Max with a 4s - 02.08.2008, 11:41 AM
Is a BEC needed to run a MM with a 4s setup, it will go in a Rustler VXL, looking at running a Neu 1509/1.5y
Happywing
02.08.2008, 12:19 PM
Yes sir.
83gt
02.08.2008, 12:49 PM
yes. rx pack or BEC required.
speedracer1129
02.10.2008, 09:22 PM
Good luck on taming that beast!!!!
miniGranis
02.11.2008, 03:22 PM
What will actually happen if using the MM on 4s WITH bec ?
I got a new in the box MM that I am about to sell and I need test the MM before selling it.
Would the MM survive a "wheels in the air" test with a Feigao 9XL on 4s and bec wire still connected to receiver ?
02.11.2008, 04:02 PM
Yes, just don't use the steering servo at all if for a short time. It's the current draw coupled with a high differential voltage that heats them up.
miniGranis
02.11.2008, 04:06 PM
I guess unplugging the steeringservo would make if "safe" when.
As I said I only need to test / arm the MM.
BTW I might be stupid here, can I test the MM with Feigao on 2S ? (I do use 2S in serial normally)
bdebde
That's All Folks!
bdebde's Avatar
02.11.2008, 04:18 PM
2s should be fine if you just want to see if the MM works.
miniGranis
02.11.2008, 05:03 PM
Thanks !
