Convert LST to Muggy???
lucias
lucias's Avatar
Convert LST to Muggy??? - 08.07.2008, 07:14 PM
Can I convert my LST to a Muggy? If I bought a chassis and center diff.. is the rest of it the same? I haven't looked at a parts diagram that would be to easy...
Not that easy
ilpufxit
ilpufxit's Avatar
Not that easy - 08.07.2008, 10:06 PM
The arms and shocks match but you'll need a lot more parts. You can pick up a Muggy pretty cheap if you look around, well worth it!
bdebde
That's All Folks!
bdebde's Avatar
08.08.2008, 12:21 AM
I believe the LST shocks and shock towers are different than the Muggy, LST has longer shocks. Also the front and rear diff ratios are different 3.3 for the LST 4.09 for the Muggy.
lucias
lucias's Avatar
08.08.2008, 12:24 AM
dang it... it was a thought.. do i need to get the stiffer chassis bdebde?
bdebde
That's All Folks!
bdebde's Avatar
08.08.2008, 12:39 AM
I would at least get the factory upgrade hard anodized chassis, the stock (silver chassis) is a bit weak. I see some rollers on ebay from time to time that already have the upgrade chassis, that would be the way to go IMO.
lucias
lucias's Avatar
08.08.2008, 01:57 AM
I guess i will have to be patient... Grrrr
