MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
08.17.2008, 11:53 PM
Originally Posted by e-mikey View Post
no. it's been like this since 6pm. The motor did get blistering hot with the 20t pinion earlier today.
If the motor got blistering hot it sounds like you may have demagged your rotor.
e-mikey
08.17.2008, 11:54 PM
Best I can do with this lense
e-mikey
08.17.2008, 11:55 PM
Anyway to tell for sure?
TruckBasher
TruckBasher's Avatar
08.18.2008, 12:04 AM
Hard to say if there are cold solder from that picture. Either that or a failure on the rotor.. IMO
E-Slayer direct drive to diff
08.18.2008, 12:15 AM
I know from experience that a blown motor will get VERY hot. I tried a CD in my Revo and it unloaded so much that the motor (10XL) spun relatively unloaded. Well, that's bad and it got very hot. Next time I ran it, it had a lot less power but got blisteringly hot. Mine never cogged though. Someone else used the rotor for a 7XL motor and it ran fine, so the rotor was fine. The coils just somewhat burned up. So I wonder if the problem is not the rotor, but one of the coils?
As others have said, it could be a cold solder joint, or just a toasted motor. I would try resoldering. Hopefully it's just that...
bensf
08.18.2008, 01:15 AM
Does it all work fine when you take the pinion off so theres no load on the motor?
e-mikey
08.18.2008, 07:20 AM
Yes bensf, actually it does.
tc3_racer_001
tc3_racer_001's Avatar
08.18.2008, 07:32 AM
thats really strange. same thing happened to my reedy 3 star in my tc3 last week and it would work fine if i pushed it (as if it was geared WAY high) then it was fine. motor was hotter than usual but the esc was quite hot... then i plugged it in again and it blew the caps and fets... grr... anyways castle wouldnt replace it under warranty (dodgy) anyway thats life.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
spaz163
Functionality with a dash of Form
spaz163's Avatar
08.18.2008, 08:21 AM
If you have had the motor out lately, maybe the mounting screws are hitting a coil and grounding out a phase... had it happen to my 8XL. Try shorter screws.
