Brushless Mini Inferno Q'S?
TwzteD
Live Fast, Die Early
TwzteD's Avatar
Brushless Mini Inferno Q'S? - 09.25.2008, 04:06 PM
I Have A Full Carbon fiber / Aluminum 1/16 MI And A Mamba 25 Esc, I have the mamba 8k motor but have herd some bad things with them in the MI Because Of Heat Issues, So Another Motor Is Needed, I Plan On Using 3s lipo ( if you know of one that fits let me know). Hows The New Micro Novak Mongoose? Any Other Suggestions Would Be Very Helpfull, i know the Hyperion and the wraith, aon and a few others work pretty well but there are more motors coming out so i figured id ask in case there is something better out. And Can You Use A Full Size Connector Like The TRX On Minis? cause i don't wanna have to change my connectors on my charger.
  Send a message via AIM to TwzteD
killajb
killajb's Avatar
09.25.2008, 05:41 PM
Hyperion long can motors work very well. I've got two mini-inferno St's and use a 5000kv Hyperion in one of them with a 25T pinion from a MLST. The thing is ballistic on 3s and had the same acceleration as 1/8 gassers at the famous Revolution Raceway in SoCal. I did turn the center diff 180 degrees to allow for a motor/electronics on one side set-up and battery on the other. Good luck!
Duster_360
09.26.2008, 09:48 PM
This motor review was for Vendetta ST, but prob similar enough to be helpful - thanks to jaejw1
http://www.rcuniverse.com/forum/m_5643067/tm.htm
As long as space permits, there shouldn't be any prob using the trx conns.
Semi Pro
Semi Pro's Avatar
09.26.2008, 10:58 PM
the wraith 7k is one of the best motors for a mini inferno st and it stays cool in my 2 cell powered mini infeno
mine is geared for around 35-40 mph
i havent found any motor that runs cool on a mini inferno after 40mph
any conector will work but trx's will be alot of bulk
TwzteD
TwzteD's Avatar
09.26.2008, 11:10 PM
aren't they discontinued? i cant find them anywhere, b-p-p still has the long can hyperion motors in stock so i may go for that, The New NUE 1105/1.5y Seems good but it needs a big esc.
Semi Pro
Semi Pro's Avatar
09.26.2008, 11:50 PM
where did you find the 1105 in stock?
the wrath is in stock at bpp, toy have to select it from the drop down tab
killajb
killajb's Avatar
09.27.2008, 03:58 AM
I'd go with a CC Sidewinder ESC, it's around the same price as my other 20-30 amp ESC's but much more capable. I've had a wraith 7k motor in my Mini Inferno St, but it ran hot on 3s. Permax has IMO the coolest running motor for 3s operation, but I could buy 2 Hyperion long cans for what I paid for it, and you can't really find them any more. Overall, my Hyperion 5k long can motor is perfect for racing on 2s and serious high-speed bashing on 3s. Combine that with the price I paid for 30c Zippy 2s and 3s lipos and I'd say I paidd $150 for motor, esc and battery.
Lucariel
Italian Brushless Style
09.27.2008, 05:50 AM
My Mini inferno run with wraith 7K and Quark 33 pro car equippeq with lipo TP 2170 3s...
Very very fast.. more than 1/8 nitro.....
ID:	5504   Click image for larger version
ID:	5505   Click image for larger version
TwzteD
TwzteD's Avatar
09.27.2008, 12:57 PM
i belive im going to keep my mamba 25 esc get the hyperion 5k long can and sell the mamba 8k motor and get 2 cheap zippy 3s 2200 mah lipos thanks for the help, this seems like the cheapest and easiest route to go
09.27.2008, 01:58 PM
Do you have any diff upgrades installed?
Lucariel
09.28.2008, 09:26 AM
I have the metal differential from mini inferno 09 nitro but the center diff is stock with rigid derlin gear (removed slipper)
TwzteD
TwzteD's Avatar
09.28.2008, 02:06 PM
about the nue motors http://www.castlecreations.com/produ...rs/nm1100.html
