e-mike
e-mike's Avatar
09.27.2008, 11:39 AM
lucky you are girls
but sometimes luck make a choice....i had 3 v1 version and i sold it....the 3 unit still working...loll or the v1 have more failure rate....
i have one unit in the box...i tink replace my mm
D8t on juice!!
e-mike
e-mike's Avatar
09.27.2008, 08:23 PM
review of my third v2 ....wow...still running....the esc close to 3 hour(1 with a bec)i remove it and the it seems run cooler....strange...?!!(5f less)and i notice that....each time that the fan come to live i check the temp...112f at the air flow and 109f at the capacitor(i know they are under the case but just to give me a idea)....for those temps everything is ok!!!...i reach those temps on 25min of run time at 18 celcius outside .... however for my 2 failed unit when i checked the temp it was higher ....122f at the air flow and 130f to the capacitor.....and they failed same outside temp and same set-up(1515 1.5d 6 cell lipo)
dont know why my 2 failed was hotter.....but i keep my finger cross for my third unit
D8t on juice!!
david lamontagn
09.27.2008, 08:33 PM
Hey Mike, you know why your V2 still alive??????? Because it's me who break-in it, and i know the secret for a long lasting MMM.....................You only have to invert the input batterie wire and plug it on 22.2 volts
You'll have a beautiful firework, but after that, your MMM will last a longtime
Hey Mike, keep it in shape, because i'll re-buy it when i'll have to replace my MM
e-mike
e-mike's Avatar
09.27.2008, 08:40 PM
im sure....that is the way to keep the mmm alive
D8t on juice!!
Sammus
Sammus's Avatar
09.27.2008, 08:47 PM
Would it definitely kill it you think? I've plugged my battery after soldering deans on backwards many-a-time with my sidewinders and mamba max and it didnt seem to hurt them...
09.27.2008, 08:52 PM
I put 10s into a MM and CC bec in error without harm... Good job they design them for muppets!
david lamontagn
09.27.2008, 09:09 PM
So i'am a muppets
e-mike
e-mike's Avatar
09.27.2008, 09:21 PM
So i'am a muppets
i think they are idiot proof
D8t on juice!!
6s lipo with mmm v2
musaed
6s lipo with mmm v2 - 10.02.2008, 02:55 PM
i was hapy only 3 time
But maybe castel will fix all problem in mmm v2000 after some years
But we will lost money for shipping
e-mike
e-mike's Avatar
10.02.2008, 04:09 PM
i guest the the v3 gonna be the right one....cc offer a very good service....of curse we have to pay for reship the unit but just think that the guy's who melt a quark or a mgm.....the service isn't good as castle...
go cc make the v3 bullet proof
D8t on juice!!
i love cc
musaed
i love cc - 10.02.2008, 04:18 PM
yes you right
and the service of castel c its perfect
and if mmm v3 good i will buy two mmm v3 compo to change my rc nitro to
electric
e-mike
e-mike's Avatar
10.02.2008, 04:21 PM
curiously on 4 units i have one v2 still running flawlesslyon 6 cell...
D8t on juice!!
killermmn
killermmn's Avatar
10.02.2008, 08:53 PM
a other one dead but whit a bec on it!!!
VintageMA
VintageMA's Avatar
10.02.2008, 10:29 PM
I have 2 working V1's on 6S with internal BEC, but popped my first V2 on 6S 10 seconds after first initialization.
I refuse to use an external BEC with the MMM!!!! Really - what's the point?
If I want to use and external BEC, and a fan mod, and a cap mod - well..... - I'll do what I did after my V2 popped...... Go back to my modded MM with fan and CCBEC.
If I buy a 6S ESC with an internal BEC I am going to use it just that way. I appreciate the time (and money) that CC has had to eat with the problem they are having and I know that eventually the product will be rock solid just the the MM is now.
Once the V3 comes out and has been proved to be a solid controller I am going to send in my popped V2 for replacement and then when I get that back I will send in my V1 controllers 1 at a time as well for an upgrade.
In the meantime I have picked up a MGM E-series 8025 6S sBEC controller that just came in the mail today - I hope to get it soldered and programmed to run this weekend. We'll see how this one goes.
“Everyone has a right to be stupid; some people just abuse the privilege.”
VintageMA
VintageMA's Avatar
10.03.2008, 11:41 PM
Just as a follow-up to my previous post to maybe help all the MMM owners out there feel a little better.
I soldered the connectors and hooked up the MGM esc and powered it on. It did the initial programming okay and just like my MMM V2 on 6S I ran the wheels just a little bit and then two huge sparks came out of the ESC and then nothing.
Very disappointing as this ESC cost almost twice that of the MMM.
I'll be contacting MGM support over the weekend, but it'll probably take at least a month with sending it back and getting a replacement.
