david lamontagn
09.27.2008, 08:33 PM
Originally Posted by e-mike View Post
review of my third v2 ....wow...still running....the esc close to 3 hour(1 with a bec)i remove it and the it seems run cooler....strange...?!!(5f less)and i notice that....each time that the fan come to live i check the temp...112f at the air flow and 109f at the capacitor(i know they are under the case but just to give me a idea)....for those temps everything is ok!!!...i reach those temps on 25min of run time at 18 celcius outside .... however for my 2 failed unit when i checked the temp it was higher ....122f at the air flow and 130f to the capacitor.....and they failed same outside temp and same set-up(1515 1.5d 6 cell lipo)
dont know why my 2 failed was hotter.....but i keep my finger cross for my third unit
Hey Mike, you know why your V2 still alive??????? Because it's me who break-in it, and i know the secret for a long lasting MMM.....................You only have to invert the input batterie wire and plug it on 22.2 volts
You'll have a beautiful firework, but after that, your MMM will last a longtime
Hey Mike, keep it in shape, because i'll re-buy it when i'll have to replace my MM
