LOSI 8T 10S Rocket...........
speedracer1129
LOSI 8T 10S Rocket........... - 11.30.2008, 07:09 PM
Hey guys,
Thought I would post some pics of my new project. It is a LOSI 8T with 8B arms to help reduce drag induced by the open wheel design. It has the 8B diffs as well for more top end. I ran 83mph with it on a Mega 22/30/1E on MMM on 5S with 18/38 gearing. New setup is HV85 on 10S with a Neu 1515 2.5D and a little more gearing......all done on the LOSI brushless conversion kit!!
Name:	LOSI 8T 001.jpg
ID:	5969   Click image for larger version
Name:	LOSI 8T 002.jpg
ID:	5970   Click image for larger version
Name:	LOSI 8T 003.jpg
speedracer1129
11.30.2008, 07:10 PM
Here are a few more pics...
Name:	LOSI 8T 004.jpg
ID:	5972   Click image for larger version
Name:	LOSI 8T 005.jpg
Takedown
WARNING: May become violent.
Takedown's Avatar
11.30.2008, 07:26 PM
You might set a record with this. I think jzemaxx's record was 81mph with his MMT on 12s. Weve got to see a video of this thing in action.
RIP- Tammy (9/14/08)
speedracer1129
11.30.2008, 07:29 PM
Thanks Takedown. I was hoping it would have been a video with the pics as I was planning on running today to test the 10S setup but weather will not allow...
Takedown
Takedown's Avatar
11.30.2008, 07:37 PM
Man, I just cant wait to see this thing bullet down the street. Should be amazing.
dirt101
dirt101's Avatar
11.30.2008, 07:48 PM
wow if you dont get 95mph I would be suprised. I hope that 2.5d can handle 10s.
rustler, lx2e, xxt cr
speedracer1129
11.30.2008, 07:55 PM
dirt,
On paper, the 1515 on 10S will pull about 61k rpm. It won't pull that in the car under load so I will be in the 60k max spec. I am shooting for about 50k under load. I am most worried about the ESC than anything else as I hope it will give me the amperage I need!! I know I should have used the HV110, but I got the HV85 in a deal brand new.
Takedown
Takedown's Avatar
11.30.2008, 07:59 PM
All in all Im wish you the best of luck with this. I expecting 90mph+.
dirt101
dirt101's Avatar
11.30.2008, 08:00 PM
i think I read somewhere that the 1y pulls around 60 amps at 60mph on 6s in an emaxx. so im "guessing" with the extra voltage, lower k/v motor, and a more aerodynamic truck the 85 amp esc shouldnt be a problem.
speedracer1129
11.30.2008, 10:01 PM
Thanks Takedown!! I appreciate it!!
speedracer1129
11.30.2008, 10:05 PM
dirt,
That is all relative to gearing. I am used to seeing 150-180 spikes in high speed 4S-5S setups. I am hoping the HV setup will calm it down to lower spikes but we will see...
azjc
11.30.2008, 11:09 PM
my first thought was you be exceeding the 85 amp limit of the ESC but its a conservative rating it should be able to take more than 100 amps IMO. I like the idea of going with a higher torque/lower kv motor and getting your speed with gearing. If you only increase your battery voltage and leave everything else the same your amperage will increase
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
12.01.2008, 05:58 AM
Sweet, whats the chances of a vid
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Semi Pro
Semi Pro's Avatar
12.01.2008, 09:04 AM
very cool truck, i cant wait to see a vid too
speedracer1129
12.01.2008, 11:19 AM
I understand AZ. Maybe I worded that comment wrong. I have not tested this setup at all yet. I saw those numbers on other vehicles that I have done. What I meant to say is that I hope with a HV setup like this I don't see those numbers!!
