my first thought was you be exceeding the 85 amp limit of the ESC but its a conservative rating it should be able to take more than 100 amps IMO. I like the idea of going with a higher torque/lower kv motor and getting your speed with gearing. If you only increase your battery voltage and leave everything else the same your amperage will increase
