Andrew32
12.18.2008, 08:05 PM
just curious...cant you just use a 5v relay?
12.18.2008, 08:07 PM
...I just need to find 5 white leds that have the correct resistors for use with 5v... Any ideas where to get those pre-assembled? I would rather not have to solder all of that up, and I have no idea what resistors to use...
White LEDs drop around 3.5v each, and you typically run LEDs at 20-25mA of current. So, (6v-3.5v)/0.02 = 125ohms. Resistors from 120ohm (21mA) to 150 ohms (17mA) will be perfect. Each one will need one of these resistors.
12.18.2008, 08:16 PM
Space is a big issue with this project. I have to fit the led control box, ubec, and whatever switch I use in a small tupperware that I have here, 1.75"x1.75"x1"... Had to custom make it to fit under the hood of the high lift...
I will order the Dual 2.5a RC Switch from robot marketplace and let you guys know how it does...
Man you are useful Brian, if only you lived closer I could bribe you and have you make all of this stuff... Would the resistor go on the neg wire? And how do you tell polarity of the led, is one of the "legs" longer than the other?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
12.18.2008, 08:27 PM
1) Doesn't matter.
2) http://encyclobeamia.solarbotics.net/articles/led.html
Daytona675
12.18.2008, 08:40 PM
This place is great: http://www.oznium.com/ the super-flux 4 are insanely bright.
12.19.2008, 03:02 AM
$4.20 shipping on all orders. Nice
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
12.19.2008, 03:52 AM
i noticed that too
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
