Chris, truggy uses 43/10 diffs while buggies use 43/13. You need to open up your diffs and count the pinion teeth.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
The difference in the pinion teeth is for the different size tires. Basically, it changes the gear ratio for each application.
So that shouldn't matter then right??? since it's geared accordingly..... also if I buy the kit which version do I buy the 36mm or 44mm I'll be running the castle 2200kv monster combo...
You'll eed the 44mm. And yes, you can gear it accordingly.
Revo with OS .18TZ
