New Hyper ST Pro
flipmac
New Hyper ST Pro - 03.20.2009, 06:09 AM
So I got this truggy from ebay brand new for $225 shipped and need some help deciding on a few things.
ESC and motor? I'm thinking MMM with 2200KV, but the RX8 is looking really nice right now. I like that Tekin has a bigger motor selection. Then again, is it worth the higher price - programmer is even extra!
I want to run 6S and go 50+ mph. With 2200KV, I would use 13T pinion; if RX8, then 1700KV with 17T. Either one with the stock spur. I don't think it would run hot, but that's just a speculation.
I want to use Mike's motor mount and battery trays, but together, they're already $115. Steep, but looks really nice.
Then, I want to do it up like Arct1k's.
What do you guys think? More pictures here.
03.20.2009, 09:10 AM
i have a couple...
Jabe
03.20.2009, 09:45 AM
Only thing with RC-Monster motor mount, is that motor goes too close to front or rear brace. So you cant change spur to smaller one.
I have MMM + Medusa 80mm 2200kv with 4S, but i wanna go 6S.
Only thing that is weak in this truck is rims, i have broken 3 rims just recently, and those were ST Pro rims (same as you have).
flipmac
03.20.2009, 10:55 PM
Arct1k: nice, I like the one on the left!
Jabe: thanks for the heads up! I wouldn't want to have the wheels shatter while going full speed down a road. What gearing are u using in your st?
Jabe
03.21.2009, 06:26 AM
I have center torsen with 52t spur and pinion is 14t, front and rear diffs are stock.
Well those rims have been broken because very bad landing...
Take a look at my thread for more infos My Hobao Hyper ST Pro conversion.
Btw. There is no need to make any new holes to chassis, you can manage with stock holes, even centerdiff can be flipped, you just need to raise Mikes motor mount for 1mm, to make acceptable clearance.
For 6S batterys (still coming), im going to use 11t. 52/10 is lowest gearing you can go with 36mm diameter 80mm lenght motor, without need of modification to center brace.
This calculator is very helpfull, when determining lowest gearing.
azjc
03.21.2009, 10:15 AM
I am running 6s in a losi 8T with a Neu 1515/2.5d and MMM, recently I was running a 18tooth pinion with a 48 tooth spur and it ran hot but I was running in grass, I went down to a 16 tooth and will try that today. I run LPR tires in mine and happy with the results
here is a link
http://www.losipartshouse.com/servle...Mounted/Detail
and for the street
http://www3.towerhobbies.com/cgi-bin...&I=LXNHW8&P=FR
Completed!
flipmac
Completed! - 05.05.2009, 03:22 AM
It took a long time, but I finally got all the stuff and they're all mounted on the truggy.
I ended up with the following:
  • MMM 2200
  • 2 x 3s 25c 5000mah
  • Mike's motor mount - man, this is a fine piece of work!
  • Custom battery trays
Running 14t (Losi) pinion gear on stock spur. I can't fit a smaller spur without grinding something, but I think it is geared fine anyway.
Sucks that I can't run it outside because of the rain.
nitrostarter
nitrostarter's Avatar
05.05.2009, 05:25 AM
Nice Job! I like the dual battery trays!
Looks great man!
N. Rustler conversion
squeeforever
squeeforever's Avatar
05.05.2009, 12:28 PM
Looks nice!
What is that on the center diff, pinion, etc? Looks like metal shavings, but I'm guessing it could be plastic as well from your battery trays. It looks like the pinion is getting worn from the metal spur though, so you might need a hardened pinion.
Finnster
KillaHurtz
Finnster's Avatar
05.05.2009, 03:47 PM
I fit a 48T spur on mine, but needed to shave a couple fins on the 1515.
You should have gotten RCM pinions ;) Those losi's look soft and is wearing badly. Won't last too long like that. I think I run 15or16T/48 on a 2.5D/5S. Everything is always dead cool.
Nice job on th HST. Great truck and an awesome price.
flipmac
05.05.2009, 03:52 PM
The white stuff is soap debris - I have a habit of using soap to lubricate spurs and pinions
I would like to use a plastic spur though. I have one on my buggy - it is quiet and works great. Is there a plastic spur do you guys know of that is around 52T and would fit for the ST?
Unsullied_Spy
Unsullied_Spy's Avatar
05.06.2009, 07:00 AM
There are no 52T spurs that I know of. Get an RC-M pinion and you won't have a problem with stripping. They're cheaper than they used to be and the only one I've ever managed to wear out was promptly replaced. My replacement has probably 100 hours of hard use on it and I have it sitting in front of me--the contact area is shiny but there's no visible wear.
05.06.2009, 09:20 AM
Nice conversion- what did you use for battery trays?
Also, you might want to consider making a series adapter out of 10ga wire.
Finnster
KillaHurtz
Finnster's Avatar
05.06.2009, 09:53 AM
IDK, I can't imagine you are going to find a plastic spur to fit the spider diff. Then you are buying a whole new diff.
Interesting on the soap. Hope the pinion works out then. I've seen some guys who have bought the OEM pinions which are not hardened as well as Mike's, and they end up chewing thru them faster. For a few extra bucks, its worth getting the best if you can. Mine on the HST is about a year old and very little wear.
brushlessboy16
brushlessboy16's Avatar
05.06.2009, 04:02 PM
Non hardened steel pinions last about 10 minutes in my truck.. then you have the joy of cleaning metal shavings up
