MetalMan
MetalMan's Avatar
03.18.2009, 02:13 PM
I am guessing that is a risk Neil is willing to take
rotary rocket
No Pistons
rotary rocket's Avatar
03.18.2009, 02:34 PM
Small correction to Bill's email.
Bill@rcalloys.com
Takedown
WARNING: May become violent.
Takedown's Avatar
03.18.2009, 02:57 PM
Its not a 5th scale unless its atleast 27in long in my opinion. Thats what most base 5th scales are without the measurement of the bumpers. My FSR 1/5 MT was 32in and they concidered it a 5th scale. All depends on the person really.
RIP- Tammy (9/14/08)
03.18.2009, 07:51 PM
I am looking at trying to go to 27-29" w/this idea. We shall see. It would be a fall project in any event.
The more I contemplate the idea, the more I am warming up to the idea of doing this
Takedown
Takedown's Avatar
03.19.2009, 12:24 PM
You should take a look into FS-Racing. Their stuff is cheap and In my opinion its quality.
Chassis I plan to use "chassis came with my 1/5 FSR mt", "solid as a rock"- http://www.fsracingusa.com/fs112125chassis.aspx
F-150 1/5 Body I plan to use "already have one but need another"- http://www.oversizerc.com/p/452928/f...l---black.html
The chassis I linked gives you plenty of room to move the front and rear assemblies back and forth to compensate with the wheelwell alignments. My 1/5 FSR MT was 32.5in long with a short bumper with that chassis and it wasnt even stretched along the chassis as long as it could be.
I would also like to get another set of rear and front center dogbones and cups. Their extremely reliable and their hardened steel.
03.19.2009, 04:36 PM
Thanks for the link....it looks like the F&R ends will bolt right up. Maybe even the center.. I enjoyed making my own chassis before, but, with this one already done.....I may skip that part all together.
othello
HV basher
03.19.2009, 08:51 PM
Interesting idea taking a truggy as base for a 1:5th scale. I quickly fitted two truggy chassis plates together. Mounted half offset crimefighter truggy tires to extend width and took some measurements to compare them with popular 1:5 scale cars.
This is about the maximum length i got with 2 chassis plates: Wheelbase 700mm / 27.56 inches. Width 430mm / 16.54 inches. Obviously too long.
I then reduced wheelbase to baja 5 length: 570mm / 22.44 inches.
Compared to a baja it is still too narrow. Baja: 460/480mm opposed to 430mm. This can be corrected somewhat with wider wheel hubs. Truggy wheels (145mm) are smaller in diameter than 1:5 scale baja tires (170mm). To be able to use 1:5 scale tires would probably require custom made wheel hubs. The chassis would need a top deck to strenghten it and might need to be narrower to fit a baja body. At least one custom center cvd is required ... cutting an original one in two halves and lengthen it with a metal tube should be an option either. Shocks would have to be adapted to carry more load.
All in all i would say it can be done. Having this much space on a chassis to fit batteries is almost a dream come true. Wheight will most certainly exceed somewhat the weight of a Savage Flux which leads me to believe one might even have enough power with a Neu 1515 (around 3KW peak).
ID:	6635   Click image for larger version
03.19.2009, 08:58 PM
In all actuality it may end up a little short of the 1/5 scale I want, however, we shall see
Thanks for your comparison
03.19.2009, 08:59 PM
Where could I get wheel extenders to use w/truggy wheels
othello
HV basher
03.19.2009, 09:10 PM
Mugen MBX5T uses extended wheel hubs or look for King Headz Wheel Hubs +12.7mm.
rootar
rootar's Avatar
03.19.2009, 09:13 PM
very interesting, im curious to soo who goes through with this and how it drives.
03.19.2009, 09:15 PM
Thanks...I was thinking of using a mbx-5T as a base vehicle seeing as I have a mbx-5 and love it.
I will need toget the biggest shocks that will fit in it to help as well as some chassis braces to make it stiiff enough
othello
HV basher
03.19.2009, 09:28 PM
You could use half offset truggy tires to increase width even further. A friend of mine drives an MBX5T which is as wide with standard offset tires as my Mantis truggy fitted with half offset tires.
rotary rocket
No Pistons
03.19.2009, 11:01 PM
I'll build one once CC puts out their 8-12 cell controller.
The 1/5 scale that I made from emaxx parts I ended up using two 7XL and two ESC. I like the idea of a single motor.
Takedown
Takedown's Avatar
03.20.2009, 11:59 AM
Good luck mag.
