best screws for mounting a 1527 neu?
fatboyelroy
best screws for mounting a 1527 neu? - 03.21.2009, 04:30 AM
what are the best quality screws (flat head 3M) i can get to mount a 1527 neu?
George16
Supermaxx
George16's Avatar
03.21.2009, 05:24 AM
Any grade 12.9 or if you can do it, drill and tap it for 4mm.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
03.21.2009, 08:24 AM
use mikes front end bell protector - then you get four screws into the can...
03.21.2009, 09:46 AM
+1 on this, best 10 bucks you can spend. And if you happen to strip the threads you can just replace the 10 dollar cover, not the 350 dollar motor...
azjc
03.21.2009, 10:02 AM
I use the cover on all my Neu motors, it also makes sure a scew wont get into the motor and make contact with the windings
Bad Karma
03.21.2009, 03:20 PM
You might want to check your motor since I have a 1527 and it has M4 screws
fatboyelroy
03.21.2009, 03:34 PM
hmm? according to this schematic http://www.neumotors.com/Site/Motor_...xxF%20-web.png all 1500 series motors are tapped for M3 screws. how can i be sure of which one i have?
RUSTY XL-5
RUSTY XL-5's Avatar
03.21.2009, 03:58 PM
+2 best $10 you can spend on your motor.
I will spank a nitro any day...guaranteed. :)
Bad Karma
03.21.2009, 04:51 PM
thread a 3mm screw in and if its loose in the threads try a 4mm, if it fits it's 4mm
fatboyelroy
03.21.2009, 09:36 PM
thanks
03.21.2009, 10:48 PM
m4 threads are an option. Both of my 1521 motors have the optional threads and 8mm shafts.
sikeston34m
sikeston34m's Avatar
03.21.2009, 11:12 PM
Is this the one?
http://www.rc-monster.com/proddetail...rontmotorcover
I guess the countersunk holes are for motor screws, then it mounts with the other threaded holes?
Is there one that catches all four screws on a Medusa? They have 2 on 25mm centers, but the other two are on 19mm centers.
03.21.2009, 11:21 PM
Is this the one?
Yep the medusa one fits all 4 threaded holes. I have one and it fits my 60mm v2 perfectly. A very good idea, as one of the threaded holes in my motor stripped out very easily. Use the drop down menu to select the medusa model.
