Getting intimate with the Feigao 580L (and MetalMan's hands) -
05.12.2009, 05:17 PM
05.12.2009, 05:31 PM
my biggest concern about that motor is the smaller screws and narrower spacing (compared to KB motors) and that might lead to broken screws and stripped threads.
05.12.2009, 06:30 PM
Nice man hands there!!
The motor is standard with 3mm mounting screws and you wanted 4mm? or vice versa?
05.12.2009, 06:34 PM
It has std m3 thread 25mm spacing, MM used a kb45 motor which had the m4 thread 30mm spacing.
05.12.2009, 06:47 PM
dude, intimate and hands are in the thread title, and you left it alone Linc? WTF?
05.12.2009, 06:50 PM
Originally Posted by MetalMan
This steel ring is what's causing the rotor to stick to my fingers in the second to last pic, that's pure magnetic strength!
i believe it was being intimate with your hands that caused the stickiness, but you can call it magnetism if you want
Soldermaster Extraordinaire
05.12.2009, 06:55 PM
*sigh*
I like how BOTH endbells are screw-captured.
05.12.2009, 06:58 PM
I am also shocked linc left this thread w/out adding his normal " humor "
05.12.2009, 08:19 PM
So far I have gotten this motor past 200 deg. F... in my XLB on 10s 3700mah. Not sure if it was undergeared or overgeared at 12/65 (center diff) and standard buggy diffs, with MT (6") tires. It seemed more like 45mph than the calculated 38mph. Will have to throw the EagleTree on there next time, and play around with the ESC (HV-110) parameters.
05.12.2009, 08:21 PM
hmm, 1051 kv? I really need a 1050. I think that extra 1 rev might draw too many amps for my setup. Are they "dyno-ing" each one to get that number or is that how they all the 12L's are rated? Just seemed funny to me.
05.12.2009, 08:34 PM
All the 12Ls are rated at 1051, this is just the general number they came up with.
05.12.2009, 09:16 PM
Humor needed?, My god Metalman, those r sexy hands, have u thought about being a hand model or getting into hand porn?
05.12.2009, 09:24 PM
I prefer my hands clean shaven tho.....
05.12.2009, 09:45 PM
I guess you are used to shaving your hands... You know why your palms get so hairy, right?
Something, anything, nothing
05.12.2009, 10:23 PM
By the looks they definitely made improvements over the 540 series. Where did you purchase this one?
Linear Mode
