Destroyed 2200KV Motor Wires
Steve Krug
Steve Krug's Avatar
Destroyed 2200KV Motor Wires - 07.04.2009, 12:17 PM
I was running my E-revo along with the MMM 2200kv system and unfortunately I flipped over (without a body on) and ended up taking some insulation off of the motor wires.
Can I open up the motor casing and solder new 10 gauge wires to the motor? Or do I have to send it in?
Thanks
07.04.2009, 01:29 PM
You could but I'm sure you'd kill your warranty - Is there enough wire to solder on the outside?
07.04.2009, 01:30 PM
One of the reasons why solder lugs would have been nice...
big greg
07.04.2009, 01:35 PM
just the insulation is gone? why not just put heatshrink over em?
07.04.2009, 01:38 PM
That's what I did on my rustler. Works fine.
nitrostarter
nitrostarter's Avatar
07.04.2009, 02:43 PM
I had put heatshrink the wire when I had the same problem.
N. Rustler conversion
emaxxnitro
emaxxnitro's Avatar
07.04.2009, 06:51 PM
yeah the motor will still work. just shrink them
808E
07.05.2009, 01:00 AM
as long as not a single strand was damaged, just shrinkwrap it.
himalaya
himalaya's Avatar
07.05.2009, 04:53 AM
+1 on shrink wrap. Actually some other motors have only shrink tubing on their leads, like the original Neu or Medusa.
....What a Blue Sky....
emaxxnitro
emaxxnitro's Avatar
07.05.2009, 04:25 PM
well. since the windings are soldered inside the motor. its just 10g wire thats involved a few strands can be broken and it will not effect performance.
theres hundreds of wires in that 10g.
808E
07.06.2009, 12:52 PM
Remove the motor, rotate it 90 -180 degree, re-attach = wires no longer the highest spot and therefore not prone to damage if you flip.
