Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
scarletboa
scarletboa's Avatar
09.14.2009, 10:32 PM
well, i was a little concerned when i heard you say it was geared for ~60mph. now, i'm a little concerned it's gonna be undergeared. i'm kinda curious to see how bad those tires will balloon.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.14.2009, 10:39 PM
I just hope the diffs hold up long enough for the tires to even have a chance to balloon.. I have a whole bunch of gears that came with it as well... I think the differential is 3:1, the Center Diff is 3:1.. Pinion is 25, Spur is 36.. and transfer from 24T to 25T on the center diff... I'm not sure how to figure that out.. I'm guessing my FDR is around 12.44... Some one please correct me, or help me figure out the FDR.. I'm going to try BrianGs Speedy thing...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
09.14.2009, 11:07 PM
Awesome project!!! Your motor mount is nice and beefy, just like the motor. Can't wait to see videos of this thing...!!!
kostaktinos_mt
09.15.2009, 09:56 AM
looks like around 13.5 to me...
i would drop to a minimum fdr of 18:1, and also lower the motor voltage to limit rpms...
60mph for a truck this large will only create broken parts imo...
  Send a message via MSN to kostaktinos_mt
aqwut
aqwut's Avatar
09.15.2009, 12:19 PM
I think you are correct, but I have to make a good video right?...
KaztheMinotaur
KaztheMinotaur's Avatar
09.15.2009, 12:29 PM
How are you connecting the cut off clutchbell stem to the motor shaft.
I haven't worked on mine for a while either...been working a lot of OT lately...always nice to get a pay check that is $600 bigger than normal.
Nard Cox
n00b
09.15.2009, 01:02 PM
*subscribed* That thing looks sick
Goodluck with the build.
aqwut
aqwut's Avatar
09.15.2009, 04:50 PM
I know what you mean about OT.. I work 55 hours every week.. straight pay... but that's extra RC money ... I'm connecting the cut off clutchbell shaft to the Brushless motor shaft with a Coupler... I want everything to look stock as possible, that way I have lots of play with the Gearing...
Coupler dimensions..
18mm wide x 22mm long
End A: 9.05mm wide x 8.0mm deep
End B: 10.05mm wide x 14mm deep
Each shaft will be held together by 2 set screws, 90 Degrees from each other... so 4 set screws total.. it will hold up without any problems.. I probably only need 1 set screw.. but rather be safe than sorry... Once it get's here I might have to shorten the coupler so it will fit in between the bearings...
Sample Video
aqwut
aqwut's Avatar
Sample Video - 09.16.2009, 11:35 PM
Finished the rear mounts for the motor...
All that's left to be done is figuring a way to mount the batteries, get new steering servo and cutting excess aluminum from the front mounts..
And this is the Coupler thingy...
Little sample video..
http://www.youtube.com/watch?v=tgTojk0XfF8
simplechamp
simplechamp's Avatar
09.17.2009, 12:54 AM
All I can say is that this thing is phenomenal. Great job.
virusss
virusss's Avatar
09.17.2009, 03:53 AM
Excellent work congratulations, I wanted to know how you felt about
protect the engine from dust, it has a
fan that sucks in air.
I have the same problem on my baja with a NEU 2215 and
I do not know how to fix it.
KaztheMinotaur
09.17.2009, 06:37 AM
Check the space between the center ring and pinion. I had to shim mine.
Yeah, you are not going to have many battery mounting options that way.
aqwut
aqwut's Avatar
09.17.2009, 01:20 PM
Thanks, I'm glad I got this project done in one week.
As you can see in the rear of the motor can is the intake. I will put a piece of foam or some kind of filter around that whole area. I'm actually leaning towards covering the whole motor(mount and all) in some kind of filter cloth/material. but for sure the rear will have a filter and the front sides of the motor will be shielded as well...
Hey, thanks.. I will shim it for sure.. I'll have to figure something out for the battery mounting... Right now, I I'm thinking of mounting the battery on an angle in the rear. But I'll have to play with it, because I want it as balanced as possible for the jumps.
Ryu James
Ryu James's Avatar
09.17.2009, 04:49 PM
looking great aqwut. i really like how you mounted the motor. that turned out well.
Jammin SCRT10 Neu 1512 1y
aqwut
aqwut's Avatar
09.17.2009, 06:19 PM
Thanks man.. after spending so much money on Batteries, Motor and ESC.. Something had to be done that could save me some money... I tried to keep it stock as possible...
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
