Swap Neu motor wires for silicone?
kazuaki
Swap Neu motor wires for silicone? - 09.25.2009, 01:56 AM
Is it possible to convert a Neu with the standard stiff wires to have flexible silicone wires? Or is this asking for trouble?
phatmonk
RC carbon junkie
phatmonk's Avatar
09.25.2009, 01:53 PM
I beleive the hardwires are part of the Neu motors windings and you shouldnt cut them.If that was what you had in mind.
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
MetalMan
MetalMan's Avatar
09.25.2009, 03:42 PM
Really Neu would have to do this for you. Each of the tiny wires have thin insulation on them that must be removed to get solder to stick to the copper. Neu does this on the last ~1/4" for you, but it might not be easy for them to do it closer to the can.
kazuaki
09.25.2009, 03:45 PM
I see. I did not realize there were individual wire inside the big one. So, is it safe to bend the stock hard wiring to get it pointed the way I want? Maybe warm them with a heat gun a little first?
MetalMan
MetalMan's Avatar
09.25.2009, 03:48 PM
You can bend them, but try not to pinch them while doing so. If they are bent too much they are likely to break.
kazuaki
09.25.2009, 03:51 PM
Nothing is ever easy...
PBO
RC-Unobtainium
PBO's Avatar
09.25.2009, 04:12 PM
I bent mine by hand over the shaft of a screwdriver...it gave the bend a nice radius albeit kinda permanent
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
kazuaki
09.25.2009, 04:22 PM
Good idea. So basically like bending tubing. Thanks
