broke a rear rocker arm today...
jokerjustin
RC-Monster Cheap Ass
jokerjustin's Avatar
broke a rear rocker arm today... - 01.26.2010, 07:56 PM
well i was doing some backyard bashing today and over shot my landing by a few feet. and i see my revo limping back towards me. i broke my rear rocker arm in half... taking pics at the moment will post them right now.
this is the jump that caused it. i landed it correctly several times. but as soon as i get a camera person i do this
RUSTY XL-5
RUSTY XL-5's Avatar
01.26.2010, 10:30 PM
Interesting break!
I will spank a nitro any day...guaranteed. :)
Semi Pro
Semi Pro's Avatar
01.27.2010, 08:20 AM
looks like your truck cant bottom out because of the springs, is that right?
if it cant bottom out all that energy has to go somewhere, just be glad it was something cheep this time
jokerjustin
01.27.2010, 09:20 AM
no it can bottom out... it just takes a good amount of effort to do it.. thats my custom dual rate setup it actually works quite well... i was thinking this was caused because i have such high oil 100wt and stiff springs that the rocker couldnt take the force
bigsteel
01.27.2010, 09:32 AM
wow,i have never broken a rocker arm,even on the biggest jumps! nicely done :D ,cool spring setup though!--josh
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
01.27.2010, 10:03 PM
same here...i have only heard on the grapevine about broken rocker's.
our RC club did a demonstration on tuesday and since i had a BL revo i was the backflip king LOL
quad backflips is about my limit though
note to all revo operators!!
them little driveshaft dust boots are more important than you think!
i tore mine as usual a while back (2 weeks), this caused the shaft to bind up and now allow it to slide. that put pressure on the diff main bearing, turned that into powdered bearing.
the now sloppy diff then stripped it's ring gear.
all because of a silly torn boot!
btw...quad backflips rock
jokerjustin
01.28.2010, 11:30 PM
after watching that video a few times does it seem like im bottoming out way to hard?
shaunjohnson
i pwn nitro
01.29.2010, 06:51 AM
just realised!
another authentic converted revo
Semi Pro
Semi Pro's Avatar
01.29.2010, 08:06 AM
how often do you jump it
i have spent alot of time jumping mine and most brakes i have had were more from stress fractures than from one bad landing, that may have been what happened to you.
on a side note, i have to drop my platinum from 14-15 feet before it bottoms out
jokerjustin
01.29.2010, 09:11 AM
semi what oil are you using? im using 70wt with custom variable pistons... and it will bottom out at around 3ft =(
If you breaker Rockers, check the posts !
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
If you breaker Rockers, check the posts ! - 01.29.2010, 06:24 PM
I didn't break a rocker and check this out.
I was installing LST2 diffs into my second E-Revo and found this while dismantleing the front bulkhead.
shaunjohnson
i pwn nitro
01.30.2010, 05:14 AM
well my 2.5 chassis has one last race left in it...i'm all out of the 2.5 chassis's now :(
going up to a 3.3 chassis
Semi Pro
Semi Pro's Avatar
01.30.2010, 05:06 PM
Originally Posted by jokerjustin View Post
semi what oil are you using? I'm using 70wt with custom variable pistons... and it will bottom out at around 3ft =(
it sounds like you have something wrong, my truck is alittle lighter that average but not enough to make that big of a difference
I'm using 50w with variable pistons, p2 rockers, and revo response tires
on a revo platinum with a vantage carbon 3.3 chassis
