BEC Jumper
Bigbudd
BEC Jumper - 02.15.2006, 09:13 PM
Just got my 12020 and was wondering.
Will cutting the heatshrink to get to the jumper void my warranty?
Also, do I need the gold plugs to connect my motor to the ESC or can I just solder them together?
Thanks guys!
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
02.15.2006, 09:31 PM
direct solder is alwyas a more effictient/safer method. Just that if u wish to change motors, it would be a hassel.
  Send a message via AIM to nbcaznmaster
Sylvester
Sylvester's Avatar
02.15.2006, 09:57 PM
No, it wont void the warranty, its ok to cut a bit of the wrap off.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
MetalMan
MetalMan's Avatar
02.15.2006, 09:59 PM
You shouldn't need to cut the heatshrink to get to the jumper. But if you do, just don't take all of it off, and you'll be fine.
Plugs are not only convenient for changing motors, but also for motor/controller removal (for whatever reason).
squeeforever
squeeforever's Avatar
02.15.2006, 10:41 PM
on a warrior you will typically have to cut it to get to the black jumper.
Cartwheels
02.15.2006, 11:14 PM
For me there was no two ways about it, I had to cut it to get to either jumper. Kind of sucks, but that's the way it is.
As I have found out, plugs make it much easier to switch motor wires around if your motor is going in the wrong direction.
Bigbudd
02.15.2006, 11:46 PM
Thanks for the quick replies guys. I'll cut out part of the shrink wrap. Another question I bought a UBEC and soldered the ends to some deans plugged it into the rx and plugged the other end to a 6 cell battery and the UBEC started to get hot so I immediately unplugged the battery. I know I triple checked my wires and solder joints before plugging anything in and everything looks right. Is the UBEC supposed to get hot like that?
Gustav
Gustav's Avatar
02.16.2006, 06:52 AM
With the BK controllers you can program it to reverse the direction so you can go ahead and solder the wires.
Cartwheels
02.16.2006, 10:47 AM
No. The ubec should not get hot at all. There is something wrong!
Bigbudd
02.16.2006, 12:58 PM
Thats what I thought. I emailed Mike last night. Thanks! I'll keep you posted.
