hacker C50 maxx with a snaped shaft...
whitrzac
Can't catch this...
whitrzac's Avatar
hacker C50 maxx with a snaped shaft... - 07.01.2010, 01:16 PM
I snaped the 3mm shaft on my C50, has anyone had any luck replacing the rotor with one from a different motor??
nitrostarter
nitrostarter's Avatar
07.01.2010, 01:24 PM
There is a 5mm shaft upgrade for that motor IIRC....
N. Rustler conversion
snellemin
2 KiloWatt RACER
snellemin's Avatar
07.01.2010, 03:09 PM
New 5mm rotor is 75 bucks from aero-model.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
whitrzac
Can't catch this...
whitrzac's Avatar
07.01.2010, 11:50 PM
I paid $50 for the motor, I would rather find something else thats cheap...
07.02.2010, 12:22 AM
L can rotor from a feigao?
whitrzac
Can't catch this...
whitrzac's Avatar
07.02.2010, 01:18 AM
I can give it a try, but I need to order one...
does anyone(linc...) that they want to get rid of for cheap
steveo
07.02.2010, 05:19 PM
the rotor from an L size motor will work i have used before, i had the same issue with my shaft, but for only $10 price difference for the L motor to use its shaft the quality is not the same
whitrzac
Can't catch this...
whitrzac's Avatar
07.02.2010, 05:55 PM
I was planing on getting an ebay/HK motor feigaos are tooo much
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
07.02.2010, 06:53 PM
http://www.castlecreations.com/produ...pair_kits.html
1512 size? rotor Diameter may be a problem. But only $25
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
whitrzac
Can't catch this...
whitrzac's Avatar
07.02.2010, 07:14 PM
the rotor from a tekin buggy motor fits, but the 4pole VS 2...
aka it cogs like a ******
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.02.2010, 07:38 PM
Another avenue if on a budget ?
http://shop.turbofanelectrics.com/ca...?categoryId=11
steveo
07.02.2010, 11:31 PM
but its the stator that is 4pole, does the rotor have to match, are they 2,4,6, pole rotors?
i dont know if there is an easy fix i would like to get a good quality rotor for my c-50 if this works
sikeston34m
sikeston34m's Avatar
07.03.2010, 12:17 AM
Yes, they have to match.
2 pole is N-S
4 pole is N-S-N-S
6 pole is N-S-N-S-N-S
This is the Magnetic Configuration of the Stator AND the Rotor.
Mismatching these doesn't work.
steveo
07.03.2010, 01:15 PM
2 pole is N-S
4 pole is N-S-N-S
thanks that is good info
