SERVO Help - Custom Build
kladal
SERVO Help - Custom Build - 07.26.2010, 10:01 PM
Hello,
I have a custom build that will only barely resemble the truck you see in the pictures below by the time it's complete.
Here are the specs:
-Motor = 2217 2y 640kv CC/Neu
-ESC = Megapower 120A
-Battery = 10s (two 5s)
-BEC = Castle Creations BEC Pro at stock 5.5V
-Tires = IMEX Swamp Kong 8.5"
-Weight = estimated 22-24 pounds
I will be installing TWO steering servos for four wheel steering. I've been advised that I need a high-torque servo.
1. Any recommendations on how much torque I should have? (Thus far I've been considering the Futaba BLS352 OR SAVOX SC-1256TG).
2. Which between these two uses less power?
3. Does anyone recommend any other servo?
4. I've been told two servos be linked via a y-hardness. How will they each attain sufficient power??
5. How do I connect these so they each do the opposite?
6. Does anyone see any problems with this steering system?
Thank you for your input!
(When I asked a servo question in my other thread, no one responded).
reno911
Smelly Nitro meet your maker!
reno911's Avatar
07.26.2010, 10:03 PM
Hitec 1/5th scale may be up your alley. Unless you run a higher bec voltage.
07.26.2010, 10:07 PM
Just install one front and rear 7980 on 7.4v - 600 oz will be enough
Reality is a 7950 at 480 oz would be OK to...
07.26.2010, 10:09 PM
That futaba is pretty weak only 250 oz
whitrzac
Can't catch this...
whitrzac's Avatar
07.26.2010, 10:38 PM
http://hobbycity.com/hobbyking/store..._.118sec_/_78g
kladal
07.26.2010, 10:42 PM
Why does this vehicle require that much torque??? Tires+weight??
Can someone tell me OR post a pic as to how I should hook up the extra LiPo battery?
Thank you.
reno911
reno911's Avatar
07.27.2010, 12:02 AM
Why an extra lipo? Can't you set the voltage on the Castle BEC?
kladal
07.27.2010, 12:05 AM
Reno911 - since I'm using two servos, what should I set the voltage to if each receives 6V? Is it a simply 6+6 = 12V? Please keep in mind I'll be connecting the two via a y-harness.
Thanks.
reno911
reno911's Avatar
Then set your voltage to 7.4 or higher if needed.
reno911
reno911's Avatar
07.27.2010, 12:06 AM
What receiver will you be using?
reno911
reno911's Avatar
07.27.2010, 12:08 AM
Thanks.
You don't need to supply twice the voltage, but it will pull more amperage. Which the BEC should be capable of.
kladal
Receiver: Airtronics MX-3 Sport 2.4GHz FHSS-2
crazyjr
crazyjr's Avatar
07.29.2010, 12:02 AM
https://www.airtronics.net/index.php...aitfile_id/56/
One problem, in the specs on the first page, max voltage is 6 volts(5 cell NIMH). I know most NIMH are higher first off the charger, not sure how much or if the reciever is really designed for higher volts
