Ofna 46T plastic spur for CRT
Candyman2
Candyman2's Avatar
Ofna 46T plastic spur for CRT - 01.22.2011, 03:29 PM
Anyone else seen/tried this?
wish i'd spotted this before I mucked about fitting the kyosho one!
http://www3.towerhobbies.com/cgi-bin...?&I=LXZAJ6&P=M
01.22.2011, 08:15 PM
Yeah, it would have been nice to have one of those 2 years ago...
01.22.2011, 10:13 PM
Well, back then, finding reliable hardened pinions was a bit of a challenge. Since Mike came out with his pinions (which work fine on both steel and plastic spurs), it's not so much of a big deal. IMO, the only benefit to the plastic spur is quieter operation.
scarletboa
scarletboa's Avatar
01.24.2011, 03:46 AM
i've tried a bunch of different brands of pinion gears and the best so far are:
robinson racing: wears at a somewhat slow pace. mine lasted ~25 runs.
novak: i've had 2 break from the steel breaking around the grub screw. slow wearing and last about ~50 runs
rc-m: only tried one and it was still wearing out pretty fast until a tooth BROKE off of it. would have lasted about 15-20 runs
castle creations: best i've tried yet. there is little or no wear on the one i'm using in my crt .5. the grub screw is a little soft though. i already stripped one, but they come with a spare. going on 20 runs with almost zero wear at all.
Candyman2
Candyman2's Avatar
01.24.2011, 05:44 AM
For me its thew noise issue, with the plastic spur you can get it running so smooth.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.24.2011, 12:01 PM
Our pinions are as good or better than anything else out there - that said, we do get an occasional "dummy" - I have seen perhaps 30 pinion gears with premature wear or broken teeth in the last few years (we have well over 5000 pinions out there) - we also replace worn or broken gears(send damaged gear and we send a replacement).
01.24.2011, 12:07 PM
I have and use RCM pinions in all my stuff and have yet to have one break or get worn down.
