CRT.5 front arms
nastety92
CRT.5 front arms - 03.26.2011, 09:01 AM
So I broke a front upper control arm on my CRT.5. The way it broke was 100% driver error.
Does anyone make a upgraded arm for the CRT.5? Other than the ones that Mikes sells, I can't see spending $175 right now eventhough I'd love those arms.
Has anyone used another plastic arm off of another vehicle?
Also, how do I get the upper arm off?
Thanks for the help,
Nick
Bazzokajoe
03.26.2011, 10:51 AM
front upper?
most people just replace with a titanium turnbuckle and be done with it ;)
brainanator
brainanator's Avatar
03.26.2011, 02:01 PM
You remove one of what is holding it on. Either the shock tower or the rear upper-arm-holder-brace-thingy.
As for arms, the SCRT10 has the same arms, if that helps you find them cheaper on ebay :) (or maybe upgrades)
nastety92
03.26.2011, 03:16 PM
Originally Posted by Bazzokajoe View Post
front upper?
Do you have a link to someone that will work?
Thanks for the help, I've obviously never had the front end apart and it seemed different than my other vehicles.
Thanks for the tip about the SCRT10 I will look into those.
Thanks everyone,
Nick
Bazzokajoe
03.26.2011, 04:05 PM
not my images, just examples of how the rie rod will install,
50mm rods are required with ball ends
nastety92
03.26.2011, 04:55 PM
Does anyone make a full kit to do this or will I have to piece together all of the parts?
Is this the PBS suspention that OFNA sells?
Thanks,
Nick
ta_man
03.27.2011, 12:11 AM
Nick
These guys sell a Jammin front arm set for $24. http://www.bartspartsrc.com/products.html
I asked about rear arms and they said "they are coming." Maybe if enough people ask about them they will come sooner.
I haven't tried these arms because I want to just buy a full set when the rears are available. If you do buy the fronts, let us know how they work out.
nastety92
04.09.2011, 08:48 PM
Here is a little update.
I ended up replacing the front plastic upper suspention arms with a set of these Traxxas turnbuckles. They are almost the exact size out of the package.
http://www3.towerhobbies.com/cgi-bin...&I=LXSGY9&P=ML
I had the truck out today running around a construction site and everything held up well.
Nick
brainanator
04.09.2011, 10:00 PM
thanks for the info. If I even run out of them upper arms I might just grab a set of those.
Kylar
04.20.2011, 01:18 PM
Ok, I replaced the upper arms as well as the steering links. So I figured i would share some pics. I was sick of the upper arms bending at the tiny turnbuckle, or breaking at the same point. I was also sick of the steering links popping off, or breaking the balls(lol)
I tested this setup pretty hard and its holding up extremely good. Best Part is it only cost about $14 total :D I used Traxxas TRA3644 for the Upper Arm, and TRA2444 for the Steering Links. Both are the perfect size, I didnt even have to adjust them. If anyone wants to do this and want instructions let me know, there are a few things you have to mod, but not much. Took me about 15 mins.
This will also work on the SCRT10
Excuse the dirt, I didnt have time to clean her after the test runs.
brainanator
04.20.2011, 01:46 PM
looks good Kylar!! I had a steering link pop off once, hope it's not recurring for me... :)
Bazzokajoe
04.20.2011, 03:43 PM
looks awesome :) instructions would be nice, looks simple enough but woul;d bed nice to see how you went but it ;)
nastety92
04.20.2011, 03:45 PM
There's really not much to this mod. Remove the front upper arms and replace with the Traxxas turnbuckle and adjust length. Same goes for the steering turnbuckle. I've found the upper arms are almost the exact length that they come out of the package.
Good luck,
Nick
Tamiya TRF801Xt-e
