a question about the Cap Pack
Erevocanuck
a question about the Cap Pack - 02.15.2012, 11:40 AM
I was wondering the difference the 01100020 version and 11000202 version
CapPack 01100020
CapPack 11000202
brian015
brian015's Avatar
02.15.2012, 01:14 PM
The 2 at the end of CapPack 11000202 obviously is their code for "$2 more expensive for the exact same thing"
FG101C
02.15.2012, 05:10 PM
Maybe it means they put post's on that will take wire larger than 12awg without having to learn a new magic trick. Using one on my baja and it works but it was not easy getting the XL wires soldered on, still not comfortable with it.
02.15.2012, 05:15 PM
Have you tried this: Tin the wires with solder. Then, using needle-nose pliers, "squish" the tinned area to flatten the area somewhat. That should reshape the wire enough to allow you to insert the flattened wire edge-wise into the solder-post groove.
I use this "trick" when soldering wires on Tekin ESC solder posts.
FG101C
02.15.2012, 10:20 PM
Really the biggest problem when using the cap pack with the XL is the posts are too close to the caps. More of a clearance issue with that 8awg wire.
Erevocanuck
02.15.2012, 11:44 PM
I was thinking that 011000202 was replacement for the mamba XL and 1100020 is from the mamba monster extreme/upgrade for the mamba monster.I looked on tower hobbies because they have a more detailed description of product and their was no 1100020 model number.
