nastety92
06.14.2012, 11:33 AM
Sounds good Freddy, what ESC are you running?
Thanks,
Nick
Tamiya TRF801Xt-e
freddy
06.14.2012, 12:28 PM
CC mamba monster
nastety92
06.15.2012, 08:34 PM
Just got my D8T with 1520 all programmed and the correct gear on.
Damn this thing is fast now. It was quick before, now it's fast. The mid range is much more than the Tekin motor and I'm still running it very easy.
5s with 17/50 gearing.
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 17
Total Voltage: 18.50
Motor KV: 1600
Tire Diameter (inches): 5.84
Tire Ballooning (inches): .10
Motor Current Draw: 140
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.94 : 1
Total Ratio: 12.64706 : 1
Tire Circumference (inches): 18.98 inches (481.97 mm)
Rollout: 1.50:1
Total Motor Speed: 29600 RPM
Vehicle Speed: 42.06 mph (67.56 km/h)
Effective KV Value: 1600
KT constant: 0.85 oz-in/A
Motor Torque: 0.62 ft-lbs
Final Torque: 7.79 ft-lbs
Final Power: 2590 watts (3.5 HP)
I think my next purchase is some 3s lipo's so I can run this motor on 6s. It should be interesting.
Video coming soon.
Nick
Tamiya TRF801Xt-e
freddy
06.16.2012, 10:51 AM
Just checked my gearing, im running with a 17t pinion and 48t spur
nastety92
06.16.2012, 01:19 PM
So your running 17/48 on 6s and I'm running,
17/50 on 5s and think its fast.
I can't wait to try 6s now.
Do you have any pictures or video of your D8T
Thanks for the help,
Nick
Tamiya TRF801Xt-e
freddy
06.16.2012, 01:32 PM
Nick
It is very fast, the temp is nice to
edit, it is a old picture. im using castle 6,5mm bullets now
06.16.2012, 04:00 PM
The 1520 motor is a beast for sure. Love it in my mbx5T. I really wish castle made these part of their normal line....they would be huge sellers as they have many uses.
06.16.2012, 04:03 PM
Other Ratio: 1
Motor KV: 1600
Rollout: 1.50:1
Video coming soon.
Nick
That stat is key to cool temps and a lot of fun!! Of course the 3.5HP and almost 8ft-lbs of torque doesn't hurt either
nastety92
06.17.2012, 09:07 AM
So what your saying is that lower RPM's keep the motor cool?
I've run that speed calculate with 6s and RPM's are 35,000. Is that to high? On 4s the RPM's are down in the 24-25,000 range and the truck feels slow.
Thanks again for the help,
Nick
Tamiya TRF801Xt-e
06.17.2012, 09:10 AM
it seems that for that motor 30K is the sweet spot. on 6s 35K is not bad either....just more fun!
nastety92
06.17.2012, 08:28 PM
So if 30-35k is it's sweet spot will it really spin up to 60k rpm's?
How about a Mamba XL on 8s? I would assume the 1520 would be out of control on 8s. I wonder how big of a vehicle it would handle being run on 8s, size wise? And would it survive.
I've been thinking of stretching my D8T or another truggy chassis. I'd run a Mamba XL and either a 2028 or another castle motor, depending on the size of the truck. My biggest problem is figuring out a body if I don't make it as big as a 1/5 scale, there really isn't anything between 1/8 and 1/5 scale.
Nick
Tamiya TRF801Xt-e
06.17.2012, 09:14 PM
Well...will the motor spin up to 60K and survive for long...probably not. Many here feel that anything under 35K is using the motor at its peak efficiency. I personally try to keep it under 30K when ever possible depending on set up. Put it this way...with my set up, the motor is only spinning 26K. Top speed is 40 or so which is fine as I am not looking for speed runs.
nastety92
06.18.2012, 08:30 AM
How are you getting 26k RPM's? If your running 5s lipo in any gearing it still comes out to 29k rpm's.
Life batteries maybe?
Thanks,
Nick
Tamiya TRF801Xt-e
d3lap
07.04.2012, 08:31 AM
Hes probly using the nominal voltage of lipos and not the 4.2v. try with 3.7
nastety92
11.21.2017, 04:33 PM
Just sold this truggy. It was a lot of fun while I had it. It had been broken and sitting around for a number of years in my basement so time to let it go off to a new home. On to the next project.
Tamiya TRF801Xt-e
