6x6 Nemesis
wellby
wellby's Avatar
6x6 Nemesis - 07.12.2012, 11:12 PM
Well I had a hard time keeping the front end down so instead of a wheelie bar I added a second set of rear tires
More pics to come.
ID:	10417   Click image for larger version
ID:	10418   Click image for larger version
some more
wellby
wellby's Avatar
some more - 07.12.2012, 11:14 PM
some more
ID:	10421   Click image for larger version
ID:	10422   Click image for larger version
nitrostarter
nitrostarter's Avatar
07.12.2012, 11:18 PM
Wowzer!! Very interesting!! How did you fab up the middle diff case?
N. Rustler conversion
wellby
wellby's Avatar
07.12.2012, 11:33 PM
The Nemesis diff cases are aluminum and split right down the middle just use 2 pinion sides and a little grinding on the case to make it all line up. The chassis extensions are made out of 4mm 7076 T6 aluminum Still have to build the top brace. Wheel base is 24"
nitrostarter
07.12.2012, 11:39 PM
Is that the natural split in the case of did you have to cut it in the middle? I'm not familiar with the Nemisis specifics.
Off topic: what kind of dog in your avatar?
wellby
wellby's Avatar
07.12.2012, 11:45 PM
They come split just use 2 cases to make one.
wellby
wellby's Avatar
07.14.2012, 03:16 PM
I missed your second question. the dog is a shih tzu normally there about 12 pounds but he is like the increadable hulk of his kind he's 23 pounds and not fat at all . His name is Teddy and he never met someone he doesn't like
07.16.2012, 01:27 AM
Cool, I did a 6x6 maxx and a 6x6 lst a while back. Looks like that nemesis diff case is alot easier to rework than the maxx and lst cases. I ran the mess out of my maxx, never got the lst powered... Maybe one day.
ed1380
07.16.2012, 01:41 AM
07.16.2012, 01:55 AM
Originally Posted by ed1380 View Post
The Virgin Mary?? Or are we talking about Allah's mom?
almost there
wellby
wellby's Avatar
almost there - 07.16.2012, 09:24 PM
Here are a few more, should be done this weekend
ID:	10435   Click image for larger version
nitrostarter
07.18.2012, 08:51 AM
Do you think the Nemesis diffs would fit in a set of Maxx bulkheads?
wellby
wellby's Avatar
07.18.2012, 09:14 AM
Don't know , I have a set of Maxx bulkheads I will take some measurements and let you know
07.18.2012, 01:18 PM
They likely will, might need shims on the case like the lst diff does.
nitrostarter
07.18.2012, 01:38 PM
I've always wanted to do an 8X8 Maxx, I'll have to check on these Nemesis diffs.
Linc- you still have the 6x6?
