1/8 GTP geared for high speed. What ESC settings for MMM?
Bmr4life
1/8 GTP geared for high speed. What ESC settings for MMM? - 08.30.2012, 07:32 PM
I got my Ofna Late Model geared for 135mph with a 2200kv on 6S. When trying to take off the car goes very slowly, but if I'm not careful with the throttle it will spin the tires. What settings should I use to get smooth take offs that are proportional to how much throttle I'm applying? Should I set it to High power take off?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.31.2012, 07:30 PM
Maybe the Torque Control will help with your take off issues ?
Post video !
Bmr4life
08.31.2012, 08:35 PM
I'll have to look into that. As for a video, I'll try to make one this weekend but I first have to figure out how to keep it on the ground. It blew over something fierce today, was probably doing 90 at the time. Landed on its lid and broke a rear body mount which has since been CA'ed.
phildogg
phildogg's Avatar
08.31.2012, 10:49 PM
If you are running the rear wing try taking it off. will help with blow overs.
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
Bmr4life
08.31.2012, 10:55 PM
Yeah, I just took it off while fixing the rear body post. I also lowered the front body mounts one notch. I'll get some video tomorrow and strap the gps on.
Bmr4life
09.01.2012, 02:13 PM
I tried 5S this morning, the issue is still there.
http://www.youtube.com/watch?v=c5BUC...ature=youtu.be
bdebde
That's All Folks!
bdebde's Avatar
09.01.2012, 08:54 PM
What firmware version are you running on the MMM? Did you update it recently? Is it an older MMM? Maybe try an earlier version of firmware.
Bmr4life
09.01.2012, 09:08 PM
Yeah, its up to date. Not the newest Beta, but close to it.
09.01.2012, 09:42 PM
I run an older firmware in my mmm....works much better. 1.24 I believe
Bmr4life
09.01.2012, 10:02 PM
I'll check it and switch to 1.24 its if not. I think I'm higher than that.
09.01.2012, 10:20 PM
I had issues when I did an upgrade a yr or so ago so I went back to old firmware and no issues
Bmr4life
09.03.2012, 12:34 PM
It was the firmware. I was running the newest which is 1.32. Bumped down to 1.24 and its good. Thanks
bdebde
That's All Folks!
bdebde's Avatar
09.03.2012, 12:53 PM
No problem....now go break the sound barrier with it
Bmr4life
09.03.2012, 01:55 PM
Yeah, that's going to have to wait yet again. I blew the tires off. Belted ofna's suck. There's a guy on youtube that went 129mph this month on GRP's so I just ordered a set of those.
