Not sure if Castle ever looks at this site anymore.. but
crazyjr
crazyjr's Avatar
Not sure if Castle ever looks at this site anymore.. but - 11.11.2021, 09:39 AM
I need a little info on a motor. In April i bought an Arrma Big Rock 3s V3 version. I have run it less than 15 times (never in wet) and the front motor bearing has blown out, I am currently trying to get it warrantied, but if i can't, I'm looking at the 1412 1y as a replacement for it.
My issue with it is the stock pinion shaft size is 5mm, where the castle site shows the 1412 1y as having a 3.175 shaft (1/8"). If the castle guys are still lurking, Can the 1412 1y be ordered with a 5mm pinion shaft?
I'm not worried about the overall strength of the 1/8" shaft, I am more than certain that it'll be plenty strong enough. But if I don't need to buy a new pinion, I'd rather not.
Thank you for any info you can share
ruudxd
11.11.2021, 03:56 PM
If the rotor is not available this might work?
https://www.amainhobbies.com/robinso...qxqaqq6zxxactz
Does the motor have damage?
Can't you just replace the bearing?
crazyjr
crazyjr's Avatar
11.11.2021, 05:18 PM
I don't have a problem with 1/8" shafts i never had one ever break and I have owned many older castle motors( mostly 1/10 but they were good). I do not doubt the strength, i just didn't want to have to get a new pinion unless i needed to. I never liked adapters. rather get a proper pinion. But thank you for the link
