Another Pillow ball question...
neweuser
neweuser's Avatar
Another Pillow ball question... - 06.19.2006, 11:00 PM
When putting them in, there is a small set screw, are you to use lock tite of some sort on this? Or can you jsut put it in snug? thanks!
squeeforever
squeeforever's Avatar
06.19.2006, 11:05 PM
Most just snug it up but I would suggest putting a dab of Loc-Tite on them.
neweuser
neweuser's Avatar
06.19.2006, 11:53 PM
thanks again, and again, and again!!! LOL, you are always dependable! thanks! really appreciate it!
squeeforever
06.20.2006, 08:41 AM
No problem!
neweuser
neweuser's Avatar
06.20.2006, 10:13 AM
I think i found a problem. My mip's are almost not long enough to the UE drive cups. I'm worried if i adjust the pillow balls in more, it'll start to tweak my turnbuckles, any suggestions?
captain harlock
RC-Monster Captain
captain harlock's Avatar
06.20.2006, 10:43 AM
How about using some spacers between the CVD's cup and the bearing to make the CVD go in a bit more?
I think some people were not able to make a MIP CVD work with UE diffs and extended suspension. Probably you may want to get a set of SuperMaxx CVDs from Mike.
Nice to meet you!
neweuser
neweuser's Avatar
06.20.2006, 10:47 AM
my tranny extended is fine. It's shafts to the wheels. If i use two spacers, it'll help, but not quite enough. If i use more than that, there is binding. Are the UE cvd's longer? I thought they were the same length...thanks!
cabking
06.20.2006, 11:23 AM
I wasted a pair of Mip's because of binding, bent them like bananas it did:032:
Can you limit the suspension travel any?
neweuser
neweuser's Avatar
06.20.2006, 11:29 AM
I'm almost as low as i can get with the gorilla suspension. It's the top of the shaft near the cup that's right at the end. The bottom seems fine and back far enough. Does that help? This is really irratating me, i measured the cups and they are the same length and not sure why these won't fit now! ARRRGGG!!!
