Brushless Lst2 Problems
DarcyRou
Brushless Lst2 Problems - 10.19.2006, 10:15 PM
Have a few problems with my brushless set-up. I have an MGM 120 controller, fiegao 8xl, ubec, 4s 8000mah lipo pack.
Problem #1 If throttle epa is at 100% when I nail it off the line it will cut out until I let off throttle
Problem #2 After running for a few minutes the mgm will have a dim light on all the time and will do nothing, after 30 minutes of being diconnected it will come back to life.
any suggestions?????
Thanks
squeeforever
squeeforever's Avatar
10.19.2006, 10:36 PM
Maybe the MGM is over heating?
DarcyRou
10.19.2006, 10:40 PM
The temps are 115 to 120 degrees
squeeforever
10.19.2006, 10:41 PM
Thats not the problem then...What about reprogramming it. Have you tried that?
DarcyRou
10.19.2006, 10:43 PM
yes a few times, i have the timing automatic, is that the right setting.
also the acceleration 0-100% is set for .65 seconds
squeeforever
10.19.2006, 10:49 PM
You might want to set the timing differently. Maybe slow down the acceleration as well...
DarcyRou
10.19.2006, 10:54 PM
i justed tried to program the controller it went through the program sequence light just goes to a dim setting and will do nothing. it did this once before and i let it set for the night and in the morning it was working again. i have a strange controller!!!
squeeforever
10.19.2006, 10:55 PM
You might want to contact Mike about it. First though, have you tried different batteries, or whatnot?
DarcyRou
10.19.2006, 10:57 PM
no I haven't tried diff batteries, this is my only lipo pack!!!
I might have to talk to mike!
Serum
Serum's Avatar
10.20.2006, 08:34 AM
Let's try the lipo's without a cut-off first. My guess is that the batteries are dropping bellow their 3V per cell..
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
10.20.2006, 10:04 AM
Thanks
Problem 1 sounds almost certainly like low voltage. I would give Serum's suggestion a try. Also, after you go through the programming sequence, did you do the autotuning? This is an important part of the programming(some settings won't take if not performed). Was the throttle EPA at 100% when you programmed the controller?
Are you using a UBEC or receiver pack? If so, did you disable the controller's BEC?
Also, what settings did you actually program into the controller? Perhaps we can discuss some of these and figure out how to get you going.
DarcyRou
10.20.2006, 11:09 AM
i checked voltage on my lipo pack 15.12 vdc, now there is that light on steady even if I shut the switch off on the esc. I turn it back on it makes the normal beep and will just turn the motor maybe a 1/8 of a turn and nothing, when I return the throttle to nuetral it beeps like I am just turning it on. (light is steady on all thru this sequence). It was running pretty good before this at 90% epa but now it will do nothing!!!!!!
