Set backs -
10.28.2006, 03:24 PM
Anyone use the set backs with Hybrids? Mine won't fit!!!
10.28.2006, 04:04 PM
Yea, I have heard that you will encounter slight problems like that when mixing UE/FLM parts...
10.28.2006, 04:52 PM
I think I can shave the bulks a tad....should be fine....RC is Modding right!
10.28.2006, 05:01 PM
Yea, you should be able to file something down to fit....Either the arm or the bulk....
10.28.2006, 05:36 PM
It's less than a mm, so i'll do the bulk, that way, if i ever change bulks to vbs, i can still use the arms.
10.28.2006, 06:11 PM
thats thinking - good choice on shaving the bulks
Hows that "Hope and Change" working out for Ya???
10.28.2006, 07:52 PM
I used mine on the FLM's. i didn't need to take off much, not a mm.
10.28.2006, 08:10 PM
Yeah, it's less than that, very minimal...jsut using a file, try it, take a little more, try it, take a little more, and walla!
Thanks walter! I thought about taking material from the arm, but then there is compromising the strength as well, so i figured, plenty there on the bulk, just shave a tad and good to go.
Serum - did it work well for you?
Hyper 7 Erevo Center Diff
10.29.2006, 12:48 PM
glad you were able to get it on.....a few more peices and your back in business
Setback rear upper arm question -
10.29.2006, 09:20 PM
Is it normal for the upper rear arm brace to be close to the diff cup? It just seems awfully close when it comes down, and it touches the diff cup. Is this normal?
10.29.2006, 09:21 PM
Got a picture of exactly what your talking about?
10.29.2006, 09:38 PM
No it's not normal....mine is a good 4mm or so from even coming close to touching the diff cup....
10.29.2006, 09:40 PM
Well after looking at mine a little bit..I think you might have your camber off on the outer knuckle....you do have those on right.....if not it will hit....and you need to use the hole on the top row..I think the second one from the end of the knuckle ( the side that faces the upper arm...)
10.29.2006, 10:35 PM
Cool, i got it.
Serum, did it work well with your Hybrids?
RC-Monster Captain
10.30.2006, 02:40 AM
I'm using my setbackers with the FLM Hybrids and it work flawlessly, not befor filing off some material from the arms, though.
BTW, neweuser, do you have some pics of your truck with the RacerX suspension? I would like to see it.
Nice to meet you!
Linear Mode
