sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
01.27.2007, 12:42 PM
Originally Posted by hyperasus
They just run to fast and hot.
Can't say I've ever really heard this problem with the MM. My 5700 runs well within the temperature parameters, even on 3S.
Sleebus
Mike.L
Mike.L's Avatar
01.27.2007, 01:43 PM
id rather have something inbetween 4600kv and 5700KV
  Send a message via MSN to Mike.L
AAngel
01.27.2007, 01:44 PM
Well, I guess I'm just doing something wrong with my diff.
jnev
jnev's Avatar
01.27.2007, 02:08 PM
I totally agree. For me, that would be the ultimate set up.
01.27.2007, 02:54 PM
Seems to me they would have been better off to release a motor around 3500kv. I don't understand why CC makes their motors so high rpm. I can't run any of their motors on my stampedes and ruslters. They just run to fast and hot. If they would make a motor in the 3000~3500kv range then we would have something to talk about.
They probably would if their ESC was spec'd to handle higher voltages (yes, we all know the MM will handle more, but that's why I said "spec'd"). A 3500kv motor on the manual listed max of 3s would only be a little under 39krpm. Maybe when the MMM comes out, you'll see some lower kv motors...
AAngel
01.27.2007, 03:24 PM
Another problem is that you can only fit so much battery on a 1/10 scale car/truck. I suppose that you could go as high a 6S if you were using a 1P pack, but at that point the pack is starting to get pretty heavy.
Running the 4600 on 4S lipo is a beast. Arguably the fastest setup that you can get in a MM system. I like the lineup that they have. I suppose that my opinion would change if there esc could handle more cells.
Nick
COOKIES!
Nick's Avatar
01.27.2007, 08:52 PM
T4 on 5700 with 3s here. All stock.
Fast but I would like faster, although, the weight is an issue, it flys - literally, lol. :D
~ Nick.
Sylvester
Sylvester's Avatar
01.27.2007, 09:27 PM
Ill stick with 2s lipo on the 5700.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
