Brushless price list? -
04.17.2007, 08:17 PM
Can anyone sum up the approx. cost, and parts list to make a brushless revo?
Lets say the setup is a basher on lipos, and it needs to be a good above average setup, not to hard to build and keeping the price as good as we can... but still we want an above average setup..
I would like to build on of these but I would like to just buy all the stuff and assemble it in a weekend if thats possible.
I also don't have much on an idea the cost, I'm hoping under $800.. the more under the better. :) Then another $250 should cover the batteries and charger?
thanks.
04.17.2007, 08:25 PM
How much it's going to cost will depend on how much of it you do yourself. Assuming that you have the truck, you can do a Mamba Max esc for 4S lipo (with the internal bec disabled) ~$129, a Feigao 8XL motor ~$80, radio ~$175 for a nice one, bec for ~$10-$40, and anything else that you don't fabricate yourself. As for the batteries, the $250 you've allocated might get you a charger and A battery, but don't forget the balancer for ~$40.
All I can tell you is to avoid throwing it together. Take your time and make sure it's done right; otherwise you're in for a lot of headaches.
04.17.2007, 08:27 PM
That's the best question....
What do you have now to start with. Do you have a revo?
04.17.2007, 08:38 PM
Yes lets say... I have the revo, the remote, etc.... Even got 3 gas motors.:) (soon to be on ebay)
Best Bang for the buck... is what I would like, but not afriad to spend where it needs to be spent. Keep the stock chassis and whatever else.
Can also do some fabricating... I own a dremel :).
04.18.2007, 04:15 PM
Well was hoping for a little more help today but guess not... :)
I'm thinking of going with the eaglesviewaerial setup. I have read this setup cannot take 'longer' sized motors, like the XLs. Are the Neu motors shorter? Which motor would you recommend? I would be running 4s lipos, 2s2p. Quark 125b controller.
04.18.2007, 04:34 PM
Sorry Trick440. I'm seriously overloaded at work otherwise I'd put something together for you. Several other s here have done conversions on REVO's so I thought they would be your best resource......perhaps they will be able to respond yet today. If not I'll try & check back.
BTW....I'm guessing by your forum name that you're a MOPAR fan? What do you have?
I've owned a '70 340 Challenger Auto, '69 Charger R/T 440 w/Hemi 4-spd, and currently I co-own a '70 Challenger (originally a 440-Six Pack/4-speed/plum crazy Car before someone butchered it) dedicated to dragracing.
04.18.2007, 04:57 PM
Thats fine I have been trying to search through threads to read up on setups. Its a slow processes, and I'm new to this so there is a learning curve on alot of the stuff I'm reading.
The setup I have found looks to be a pretty good beginer setup as far as being easy to install.
I did some research and it look like a Neu motor will fit. Sounds like I would have a pretty good setup. The price would be about $600 motor and controller, & $100 for the kit.
I would like some second opinions. and suggestions if anyone has any.
5.0, no mopar. The 440 is a honda atv (400ex) bored to a 440. Everything done to the motor, (except stroked,) and 30hp shots of nitrous. My sand dunes ride.
04.18.2007, 05:02 PM
The NEU motor is a great one. Best "bang for the buck is a Mamba Max w/Feigao XL or a Warrior 9920 with a Feigao. Past that and you look to the Quark 125b/Neu or Quark 125b/Lehner 1940.
I'm doing the Mamba Max w/Neu 1515 with the intent of moving my Mamba Max to another car/truck when the Monster Mamba Max arrives.
