06.25.2007, 10:50 AM
Now thats a battery strap...
gasshead
j-womp
gasshead's Avatar
06.25.2007, 11:14 AM
yeah no doubt. i like the idea of useing that husky srap. i took straps off a back pack. and used one of the little clips things for uick removal of the battery.
  Send a message via AIM to gasshead
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
06.25.2007, 11:28 AM
i picked up some black 2" x 24" nylon straps with a buckle at one end (velcro closure like gorilla straps, but makes one continuous loop) pretty cheap from feebay. 12 of them for $10. i had to cut some down and reinforced the connection points with monofiliment. they work great - much, much stronger than the flimsy gorilla straps and much cheaper too. they work perfectly with the FLM chassis.
Eflite Blade 400 heli on 3s
asianplayer
06.25.2007, 09:46 PM
so i just went to go pick up my battery from maxamps today. I got a 4s 8000mah as planed. it looks sweet and i cant wait to get everything here so i can use it.
asianplayer
06.26.2007, 01:57 AM
Hey everyone i have another, yes another question, on my ESC there is a universal connector comming out of it, where does that go? or so i not even need it?
gasshead
j-womp
gasshead's Avatar
06.26.2007, 08:34 AM
3 wires will go to the motor you need to get deans for the enpty battery leads, there is one connector with 3 wires that goes to the receiver, if ur running a receivr pack you need to remove one of those wires(not shure of which one on the MM)and then there is the onoff switch
Getter Robo
RC Monster Fiberglass
Getter Robo's Avatar
06.26.2007, 01:31 PM
@Asianplayer: It looks like you have set the turn ration of your dremel too high and were cutting too hasty. I experienced this with PC Case modding, high turn ratios can make the dremel jump especially if you hold them with one hand (steel is really nasty!)
Tesla 4 president!
